I already installed a node on Centos with Tomcat and mySQL. Now I'm trying to
install GeoNetwork on Ubuntu with Tomcat and Postgres.
With GN 2.2 and GN 2.4 I have the same problem. Tailing the catalina.out
file I have the following error. Any suggestion?
Thank you very much for your help.
Bye
Paolo
99596 [http-8080-6] INFO jeeves.request -
99597 [http-8080-6] INFO jeeves.request - HTML Request (from 130.192.92.135)
: /geonetwork/srv/en/main.home
99597 [http-8080-6] DEBUG jeeves.request - Method : GET
99597 [http-8080-6] DEBUG jeeves.request - Content type : null
99597 [http-8080-6] DEBUG jeeves.request - Accept :
application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
99597 [http-8080-6] DEBUG jeeves.request - Session id is
C56D3EAE8FE5416A50529A8C213FDDE9
99598 [http-8080-6] DEBUG jeeves.request - Session created for client :
130.192.92.135
99606 [http-8080-6] INFO jeeves.service - Dispatching : main.home
99606 [http-8080-6] DEBUG jeeves.service - -> no input parameters
99606 [http-8080-6] INFO jeeves.service - -> dispatching to output for :
main.home
99931 [http-8080-6] INFO jeeves.service - -> transforming with stylesheet :
/usr/local/geonetwork/web/geonetwork/xsl/main-page.xsl
Recoverable error
XTRE0540: Ambiguous rule match for /
Matches both "document-node()" on line 13 of
file:/usr/local/geonetwork/web/geonetwork/xsl/main-page.xsl
and "document-node()" on line 34 of
file:/usr/local/geonetwork/web/geonetwork/xsl/main.xsl
100980 [http-8080-6] INFO jeeves.service - -> end transformation for :
main.home
100980 [http-8080-6] INFO jeeves.service - -> output ended for : main.home
100980 [http-8080-6] INFO jeeves.service - -> dispatch ended for : main.home
Update: SETTING DEFAULT CONTEXT
View this message in context: http://n2.nabble.com/Issue-on-Ubuntu-and-Tomcat-tp3310768p3310768.html
Paolo,
the messages about "Recoverable error" occur in various places since Xalan
was replaced by Saxon for XSLT transformations. Generally this does not mean
that the transformation actually fails or that some problem result.
In GN2.2 it was still Xalan, however; so I think it is not likely you see
exactly this same error in your log for GN2.2.
Still I guess you wouldn't post this if all went well for you. What are the
symptoms of the problem you're having ?
Kind regards
Heikki Doeleman
On Thu, Jul 23, 2009 at 6:39 PM, Paolo Pasquali <paolo.pasquali@anonymised.com>wrote:
to
Bye
Paolo
130.192.92.135)
130.192.92.135
main.home
Recoverable error
main.home
main.home
GeoNetwork-users mailing list
Heikki,
the symptoms are that as soon as I restart Tomcat the java cpu usage goes to
100% and keep there. The other thing is that intermap cannot load the map.
The message is:
Exception 'Result of expression 'li1' [undefined] is not an object.'
Though these two things I guess are not related, they happen both with GN
2.2 and 2.4. When I installed GN 2.2 on Centos I didn't have the cpu issue
while the map issue I solved it (this time I can't).
The "recoverable error" was the only thing I found until now.
Thanks for your reply. Any suggestion is welcome.
Bye
Paolo
Heikki Doeleman wrote:
Paolo,
mean
the
Kind regards
Heikki Doeleman
trying
to
Bye
Paolo
130.192.92.135)
130.192.92.135
main.home
Recoverable error
main.home
main.home
main.home
View this message in context: http://n2.nabble.com/Issue-on-Ubuntu-and-Tomcat-tp3310768p3314360.html
Ciao Pasquale,
are you using tomcat from repository? I installed GN on 2 different Ubuntu Server ( 8.04 LTS 64bit ) using Java and PostgreSQL from
repository and Tomcat from official site and all was fine.
The only issue I can recall was on a virtual server, but the CPU usage was related to a kernel problem.
Bye
Luca
Paolo Pasquali ha scritto:
Heikki,
The message is:
Bye
Paolo
ME Luca Casagrande
Open Source GIS analyst and developer
Gfosservices SA
http://www.gfosservices.com
skype: lucacasagrande
email: luca.casagrande[at]gmail.com
Hi Luca,
no issues with Tomcat for months except with the GN webapp. Tomcat is 6.0.18
and JVM 1.6.0_10-b33 from repository.
Ciao
Paolo
Luca Casagrande-2 wrote:
Ciao Pasquale,
Bye
Luca
Heikki,
to
map.
The message is:
issue
Bye
Paolo
ME Luca Casagrande
Gfosservices SA
View this message in context: http://n2.nabble.com/Issue-on-Ubuntu-and-Tomcat-tp3310768p3314443.html
One step forward.
I found out that the Blue Marble tiff was corrupt so intermap couldn't load
it.
So I commented it out and intermap now loads only the boundaries.
But while opening the map viewer the java cpu usage goes again 100%.
Paolo
Paolo Pasquali wrote:
Hi Luca,
6.0.18 and JVM 1.6.0_10-b33 from repository.
Ciao
Paolo
Ciao Pasquale,
Bye
Luca
Heikki,
goes to
map.
The message is:
GN
issue
Bye
Paolo
ME Luca Casagrande
Gfosservices SA
View this message in context: http://n2.nabble.com/Issue-on-Ubuntu-and-Tomcat-tp3310768p3315742.html
