[GeoNetwork-users] Issues with "directories"/"directives"/"sub-template indexes" [SEC=UNCLASSIFIED]
Hi Guys
I'm having issues configuring sub-templates in GeoNetwork 3.4.2 for a complex editing interface using ISO19115-3 records
                In 3.4.1:
Editing interface works
Directives work
Labelling of sub-template instance labels fails for some
Unable to successfully update index-subtemplate.xml
    Sub-template indexes worked in GN3.2.1
I have added the schema_plugin(s) iso19115-3
                No issues (from GitHub)
I have added new iso19115-3/layout/config-editor.xml
                No major issues (copied from 3.2.1 instance)
I have added templates for:
                Describing data (<mdb:MD_Metadata>..</mdb:MD_Metadata>)
                                No issues
                Describing services (<mdb:MD_Metadata>..</mdb:MD_Metadata>)
                                No issues
                Directories/directives
                                Legal constraints (<mco:MD_LegalConstraints>...</mco:MD_LegalConstraints>)
                                                No issues (out of the box directive and sub-template index)
                                Legal constraints (<mco:MD_SecurityConstraints>...</mco:MD_SecurityConstraints>)
                                Organisation & Contacts [& re-settable role] (<cit:CI_Responsibility>...</cit:CI_Responsibility>)
                                Organisation (<cit:CI_Organisation>...</cit:CI_ Organisation >)
                                                ISSUE: does not present name
        Needed as can have multiple organisation with the same role
                                Individual (<cit:CI_Individual>...</cit:CI_Individual>)
        Needed as can have multiple individuals with the same role
        Needed as can have multiple individuals within the same organisation with the same role
                                Address (<cit:CI_Address>...</cit:CI_Address>)
                                                ISSUE: does not present "label" (from deliveryPoint, or city)
        Needed as can have multiple addresses per organisation and/or individuals with the same role
                                Format (<mrd:MD_Format>... </mrd:MD_Format>)
                                                ISSUE: does not present title
        Needed
Adding the directive to the schema_plugins/iso19115-3/index-fields/index-subtemplate.xml file
ISSUE: causes GN to crash
Any hints?
    Must I add text into the geonetwork/catalog/locales/en-editor.json file
                So that the sub-templates have appropriate labels?
                                Seemed to make GN to crash (might have been a compounded issue)
Suggestions gratefully accepted!
e
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
Hi
Le mer. 23 mai 2018 à 08:28, Bleys, Evert <Evert.Bleys@anonymised.com>
a écrit :
Hi Guys
                In 3.4.1:
Directives work
                                No issues
                                No issues
                                Legal constraints
                                Legal constraints
                                Organisation
name
        Needed as
For subtemplates, if you don't have a template in index mode (eg.
https://github.com/metadata101/iso19115-3/blob/3.4.x/src/main/plugin/iso19115-3/index-fields/index-subtemplate.xsl#L75)
matching the root element of the type of your subtemplate, it need further
work. In ISO19115-3, we have CI_Responsibility which could contains
CI_Organisation (which may have CI_Individual) or CI_Individual. For now,
the subtemplate have been configured to support CI_Responsibility as
subtemplate (similar to what 139 does). It makes sense to have
CI_Organisation (to first support one role, multiple org) and maybe also
CI_Individual. An issue I see, is that xlink mode will not work easily on
this as you could create an organisation with different sets of individual
and for this to be supported the xlink should track the list of individuals
to add. Maybe we could progress step by step on this.
                                Individual
name
        Needed as
        Needed as
role
                                Address
        Needed as
same role
</mrd:MD_Format>)
title
        Needed
When, on stratup ? on indexing ?
Any hints?
The only label to add in editor-json is the placeholder eg.
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/locales/en-editor.json#L265-L268
If not set, it should not be a blocker to use the new subtemplate type.
If this cause issue in the app, check json formatting but this should not
even block the editor - it will just not display label translations
HTH
Francois
e
BLEYS Evert Mr
Data Manager
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
