[GeoNetwork-users] Issues with "directories"/"directives"/"sub-template indexes" [SEC=UNCLASSIFIED]
Thanks
For subtemplates, if you don't have a template in index mode (eg. https://github.com/metadata101/iso19115-3/blob/3.4.x/src/main/plugin/iso19115-3/index-fields/index->subtemplate\.xsl\#L75<https://github.com/metadata101/iso19115-3/blob/3.4.x/src/main/plugin/iso19115-3/index-fields/index->subtemplate\.xsl\#L75>\) matching the root element of the type of your subtemplate, it need further work. In ISO19115-3, we have CI_Responsibility which could contains >CI_Organisation (which may have CI_Individual) or CI_Individual.
CI_Responsibility
Appears in “Directory Manager”
works fine
They do work from the record creation interface
MD_Format
Appears in “Directory Manager” with blank labels
work from startup, but have no labels: so it’s a bit tricky to select the correct snippet when adding to a record
Can add entries after startup
CI_Individual & CI_Organisation
            cannot add entries after startup
CI_Address
CI_Contact
            Cannot see directory at all
An issue I see, is that xlink mode will not work easily on this as you could create an organisation with different sets of individual and for this to be supported the xlink should track the list of individuals to add.
I am instantiating them in the record XML, not as xlink references
Maybe we could progress step by step on this.
If I start adding into index-subtemplate.xml
ISSUE: causes GN to crash
When, on stratup ?
Yes on startup
on indexing ?
Don’t get that far
I have attached a XML file with the additional index fields required.
I would appreciate it if you could identify where I went wrong.
NOTE I have split the MD Constraints into the three specialisations as the labels should come from different parts for each
e
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@...1564...
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
(attachments)
additionalIndexFields.xsl (11.1 KB)
