Hi
I have been trying to use postgres with Geonetwork 3.2.0 using the jetty servlet engine that comes with the software.
Geonetwork works fine when I use the default H2 database.
Then when I configure the postgres database I have issues (using the default postgres.xml file)
The database connection works fine as the database is populated with empty tables. So I know it is not the connection. However I get a 503 error when trying to view geonetwork.
Looking at the output logs I notice that it is trying to start two default nodes
First from the output.log
java.lang.IllegalArgumentException: Two nodes where defined as the default. This is not acceptable.
at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListe
ner.java:132)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:837)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.jav
a:533)
Then from geonetwork
2016-10-18 15:45:55,876 WARN [geonetwork.databasemigration] - Database does not contain any version information. Check that the database is a GeoNetwork database with data. The database is probably empty, no migration required.
2016-10-18 15:45:56,130 WARN [org.apache.camel.management.DefaultManagementLifecycleStrategy] - This CamelContext(harvest-wfs) will be registered using the name: harvest-wfs-1 due to clash with an existing name already registered in MBeanServer.
2016-10-18 15:45:57,047 FATAL [jeeves.engine] - Raised exception during init
2016-10-18 15:45:57,047 FATAL [jeeves.engine] - Exception : java.lang.IllegalArgumentException: Two nodes where defined as the default. This is not acceptable.
2016-10-18 15:45:57,047 FATAL [jeeves.engine] - Message : Two nodes where defined as the default. This is not acceptable.
2016-10-18 15:45:57,048 FATAL [jeeves.engine] - Stack : java.lang.IllegalArgumentException: Two nodes where defined as the default. This is not acceptable.
Andrew Rae
Hi Andrew
Can you check in the folder geonetwork/WEB-INF/config-node how many files
are there? If there's only a file srv.xml, can you verify that only the
entry related to postgres is un-commented, like this:
<!-- Uncomment the database configuration you need to use -->
<!--<import resource="../config-db/h2.xml"/>-->
<!--<import resource="../config-db/jndi-postgres-postgis.xml"/> -->
<!--<import resource="../config-db/oracle.xml"/>-->
<!--<import resource="../config-db/mysql.xml"/> -->
<!--<import resource="../config-db/db2.xml"/> -->
*<import resource="../config-db/postgres.xml"/>*
<!--<import resource="../config-db/sqlserver.xml"/> -->
<!--<import resource="../config-db/postgres-postgis.xml"/> -->
Jose García
On Tue, Oct 18, 2016 at 5:16 AM, Andrew Rae <Andrew.Rae@anonymised.com> wrote:
Hi
nodes
ner.java:132)
a:533)
migration required.
init
Andrew Rae
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
" Two nodes where defined as the default. This is not acceptable." is
pretty clear, you can't have more than one default node. See
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/config-node/srv.xml#L36.
In the doc "Only one default node is allowed." See
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/using-multinode-mode.html
Maybe we should only log a warning and use the first default node and
continue.
HTH.
Francois
2016-10-18 8:04 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Andrew
Jose García
> Hi
empty
when
default
> nodes
> ner.java:132)
> a:533)
database
> migration required.
will
> init
> Andrew Rae
> projects/geonetwork
projects/geonetwork
