I installed geonetwork 3.2 by deploying the war file under tomcat 7. I have also installed solr however, I think there is problem with the collection I made for geonetwork. In the documentation it is said that we should run this command:
solr-6.0.0/bin/solr create -p 8984 -c catalog_srv -d src/main/solr-cores/catalog
However, I don't know what path should be replaced by src/main/solr-cores/catalog, as I do not have such directory which should contain required config files (schema.xml and solrconfig.xml as example)
Best,
Samin Payro
