[GeoNetwork-users] Issues with WMS GetFeatureInfo
Hello
I can add layers using WMS Services to the map viewer of geonetwork 3.2.1
<http://osgeo-org.1560.x6.nabble.com/file/n5315982/001.png&gt;
I can also see their attributes clicking on the layer loaded using a WMS
Service generated in Geoserver (using a directory of shapefiles as datastore
in Geoserver).
<http://osgeo-org.1560.x6.nabble.com/file/n5315982/002.png&gt;
But, when I try to see the attributes of a layer loaded from a WMS Service
generated in Geoserver (using PostGIS as datastore), Geonetwork shows the
number or records but don't show the atributes of the layer.
<http://osgeo-org.1560.x6.nabble.com/file/n5315982/003.png&gt;
The same happens when I try to see the attributes of a layer loaded using a
WMS Service generated in ArcGis.
Using Firebug I can see that the input parameters are the same en both
cases:
http://localhost:8080/geoserver/segdi/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&FORMAT=image%2Fpng&TRANSPARENT=true&QUERY_LAYERS=Conc_Maderables4326&LAYERS=Conc_Maderables4326&INFO_FORMAT=application%2Fvnd.ogc.gml&I=50&J=50&CRS=EPSG%3A3857&STYLES=&WIDTH=101&HEIGHT=101&BBOX=-7821036.734139234%2C-1270842.0322693405%2C-7790156.174712023%2C-1239961.4728421294&FEATURE_COUNT=2147483647
But, the responses are different:
First Case (WMS Service from a shapefile, that works):
<?xml version="1.0" encoding="UTF-8"?><wfs:FeatureCollection
xmlns="http://www.opengis.net/wfs&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
xmlns:gml="http://www.opengis.net/gml&quot; xmlns:segdi="segdi"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xsi:schemaLocation="http://www.opengis.net/wfs
http://localhost:8080/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd segdi
http://localhost:8080/geoserver/segdi/wfs?service=WFS&amp;version=1.0.0&amp;request=DescribeFeatureType&amp;typeName=segdi%3AConc_Maderables4326&quot;&gt;&lt;gml:boundedBy&gt;&lt;gml:null&gt;unknown&lt;/gml:null&gt;&lt;/gml:boundedBy&gt;&lt;gml:featureMember&gt;&lt;segdi:Conc\_Maderables4326
fid="Conc_Maderables4326.124"><segdi:the_geom><gml:MultiPolygon
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;&lt;gml:polygonMember&gt;&lt;gml:Polygon&gt;&lt;gml:outerBoundaryIs&gt;&lt;gml:LinearRing&gt;&lt;gml:coordinates
xmlns:gml="http://www.opengis.net/gml&quot; decimal="." cs="," ts="
">-70.07564076,-11.17688037 -70.0299291,-11.17704115
-69.98406308,-11.17719545 -69.98421587,-11.22240817
-69.98436932,-11.26762076 -69.98452343,-11.3128332 -69.98454592,-11.31941612
-69.9873747,-11.31669392 -69.98867487,-11.31484489 -69.98898717,-11.31281831
-69.99001648,-11.30614146 -69.99055711,-11.30490986 -69.99381249,-11.3017431
-69.9949609,-11.30099776 -69.99630869,-11.30078525 -69.99698841,-11.30087338
-69.99755404,-11.30125127 -69.99930025,-11.30439219
-70.00082241,-11.30574343 -70.00261558,-11.30598151
-70.00414584,-11.30554228 -70.00583757,-11.30403548
-70.00681374,-11.30251302 -70.0072655,-11.30053117 -70.0075263,-11.29535796
-70.00811411,-11.29413522 -70.00892016,-11.29334578
-70.00981886,-11.29326133 -70.01069499,-11.29352058
-70.01282199,-11.29484257 -70.01382044,-11.29577053
-70.01430614,-11.29653748 -70.01440659,-11.29856266 -70.01481225,-11.2996102
-70.01746429,-11.30301013 -70.01905892,-11.3042706 -70.01995697,-11.30415899
-70.02180708,-11.30325741 -70.0229402,-11.30250297 -70.02352438,-11.30180468
-70.02398714,-11.30053714 -70.02420467,-11.29874597
-70.02369716,-11.29805146 -70.0235641,-11.29693969 -70.02413694,-11.29522868
-70.02480307,-11.29463862 -70.02684299,-11.29472198 -70.02794971,-11.2950075
-70.02846806,-11.29544879 -70.02930406,-11.29753469
-70.03035501,-11.29879699 -70.03068986,-11.30116495
-70.03104153,-11.30223073 -70.03161391,-11.30320533
-70.03215248,-11.30361036 -70.03317161,-11.30317277 -70.0348744,-11.30024611
-70.03655954,-11.29839556 -70.03718051,-11.29806786
-70.04107177,-11.29817176 -70.04261882,-11.29852802
-70.04374288,-11.29964532 -70.04440882,-11.30082753
-70.04443009,-11.30172266 -70.04382951,-11.30412102
-70.04387548,-11.30479904 -70.04424567,-11.30534932
-70.04512628,-11.30556324 -70.04603801,-11.3055148 -70.04889252,-11.30409409
-70.05023635,-11.3040622 -70.05189856,-11.30560255 -70.05669457,-11.31107421
-70.05734682,-11.31170484 -70.05798101,-11.31193768
-70.05884942,-11.31170851 -70.06089713,-11.30991079
-70.06241185,-11.30939898 -70.06294404,-11.30899016
-70.06452148,-11.30623562 -70.06603527,-11.3022244 -70.06741868,-11.30043807
-70.06908781,-11.29973579 -70.07091108,-11.29960261 -70.0761002,-11.30079548
-70.07647244,-11.30088455 -70.07935177,-11.30034058
-70.08110365,-11.30079535 -70.08161553,-11.30124559
-70.08185779,-11.30186863 -70.08225687,-11.30704842
-70.08286927,-11.30795946 -70.08397494,-11.30801871
-70.08561506,-11.30721697 -70.08652668,-11.30653546
-70.08711637,-11.30536683 -70.08890001,-11.30497146
-70.09003021,-11.30508485 -70.09062875,-11.30573369
-70.09127631,-11.30836262 -70.0926971,-11.31012966 -70.09494535,-11.31204736
-70.09584668,-11.31205307 -70.09649207,-11.3124395 -70.09721265,-11.31287085
-70.09832785,-11.31272204 -70.09877053,-11.31243104
-70.10002945,-11.31160352 -70.10105091,-11.30910406
-70.10391924,-11.30687802 -70.10486033,-11.30508414
-70.10782958,-11.30194443 -70.10837893,-11.30095677
-70.10914372,-11.29859388 -70.11198626,-11.29395359
-70.11353799,-11.29247388 -70.11547566,-11.29181555
-70.11647615,-11.29230911 -70.1170326,-11.29302135 -70.11932986,-11.30011987
-70.12074789,-11.30188678 -70.12191559,-11.30244298
-70.12902749,-11.30211756 -70.13063999,-11.30293425 -70.13475121,-11.3030632
-70.13654963,-11.30273983 -70.1425552,-11.30052852 -70.14390307,-11.30030631
-70.14527771,-11.30106053 -70.14824202,-11.3047925 -70.14910575,-11.30499712
-70.14989219,-11.30456005 -70.1514586,-11.30263703 -70.15254719,-11.30229823
-70.15340301,-11.30217307 -70.1533799,-11.29639049 -70.16770089,-11.2963344
-70.20944612,-11.29616695 -70.21349604,-11.2941476 -70.22772971,-11.28704986
-70.25466203,-11.2932664 -70.25438627,-11.29384226 -70.25483825,-11.29350074
-70.2584429,-11.2929972 -70.25929528,-11.2923697 -70.26137304,-11.29085088
-70.26261036,-11.29026694 -70.26462421,-11.28985148 -70.26691,-11.28982364
-70.2677378,-11.29019081 -70.26829397,-11.29089369 -70.26836216,-11.29201458
-70.2680323,-11.29447535 -70.26819189,-11.29535172 -70.27065643,-11.29807177
-70.27194846,-11.29898849 -70.27306758,-11.29919164
-70.27486266,-11.29888554 -70.27671342,-11.29757556
-70.27788045,-11.29618715 -70.27873452,-11.29459212
-70.27889606,-11.29370533 -70.27878947,-11.29258461
-70.27844443,-11.29127505 -70.27767627,-11.29015719
-70.27752103,-11.28858459 -70.27827571,-11.28646557
-70.27957782,-11.28462448 -70.28062894,-11.28422211
-70.28268276,-11.28418611 -70.28335272,-11.28433692
-70.28533076,-11.28541336 -70.28728786,-11.28480812
-70.28980153,-11.28492378 -70.29115625,-11.28475514
-70.29597378,-11.28218437 -70.29733241,-11.2819976 -70.30076563,-11.28207298
-70.30233331,-11.28177677 -70.30351737,-11.28109345 -70.30504215,-11.2797305
-70.30498194,-11.26638527 -70.30477854,-11.22117777
-70.30457602,-11.17597013 -70.25879127,-11.17616617
-70.21300368,-11.17635523 -70.167219,-11.17653727 -70.12142954,-11.17671232
-70.07564076,-11.17688037</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></segdi:the_geom><segdi:MODALIDAD>POR
CONCURSO PUBLICO</segdi:MODALIDAD><segdi:TITULAR>MADERERA PAUJIL
S.A.C.</segdi:TITULAR><segdi:CONTRATO>17-TAH/C-J-033-02</segdi:CONTRATO><segdi:AREA_SIG>46913.99</segdi:AREA_SIG><segdi:AREA_APROB>46914.0</segdi:AREA_APROB><segdi:FECHA_INI/><segdi:FECHA_TER/><segdi:CONCURSO>1ER
CONCURSO PUBLICO</segdi:CONCURSO><segdi:REGION>MADRE DE
DIOS</segdi:REGION><segdi:ATFFS_GR>TAHUAMANU</segdi:ATFFS_GR><segdi:FUENTE>DGFFS-DICFFS</segdi:FUENTE><segdi:DOC_LEGAL/><segdi:RES_OSIN>RG
N�
022-2008-INRENA-OSINFOR</segdi:RES_OSIN><segdi:RES_DG_GR/><segdi:SITUACION>VIG</segdi:SITUACION><segdi:NUM_CONC>35</segdi:NUM_CONC></segdi:Conc_Maderables4326></gml:featureMember></wfs:FeatureCollection>
Second case (WMS Service from a table in PostGIS, that doesn't work):
http://localhost:8080/geoserver/segdi/wfs?service=WFS&amp;version=1.0.0&amp;request=DescribeFeatureType&amp;typeName=segdi%3Aconc_maderables4326&quot;&gt;&lt;gml:boundedBy&gt;&lt;gml:null&gt;unknown&lt;/gml:null&gt;&lt;/gml:boundedBy&gt;&lt;gml:featureMember&gt;&lt;segdi:conc\_maderables4326
fid="conc_maderables4326.124"><segdi:modalidad>POR CONCURSO
PUBLICO</segdi:modalidad><segdi:titular>MADERERA PAUJIL
S.A.C.</segdi:titular><segdi:contrato>17-TAH/C-J-033-02</segdi:contrato><segdi:area_sig>46913.99</segdi:area_sig><segdi:area_aprob>46914.0</segdi:area_aprob><segdi:concurso>1ER
CONCURSO PUBLICO</segdi:concurso><segdi:region>MADRE DE
DIOS</segdi:region><segdi:atffs_gr>TAHUAMANU</segdi:atffs_gr><segdi:fuente>DGFFS-DICFFS</segdi:fuente><segdi:res_osin>RG
N�
022-2008-INRENA-OSINFOR</segdi:res_osin><segdi:situacion>VIG</segdi:situacion><segdi:num_conc>35</segdi:num_conc><segdi:geom><gml:MultiPolygon
srsName="EPSG:4326"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates
">-70.07564076,-11.17688037 -69.98406308,-11.17719545
-69.98454592,-11.31941612 -69.99055711,-11.30490986
-69.99630869,-11.30078525 -70.00414584,-11.30554228
-70.00892016,-11.29334578 -70.01905892,-11.3042706 -70.02684299,-11.29472198
-70.03215248,-11.30361036 -70.03718051,-11.29806786
-70.04261882,-11.29852802 -70.04424567,-11.30534932 -70.05023635,-11.3040622
-70.05798101,-11.31193768 -70.06741868,-11.30043807
-70.07935177,-11.30034058 -70.08286927,-11.30795946
-70.09003021,-11.30508485 -70.09721265,-11.31287085
-70.11547566,-11.29181555 -70.12191559,-11.30244298
-70.14390307,-11.30030631 -70.14910575,-11.30499712
-70.15340301,-11.30217307 -70.1533799,-11.29639049 -70.20944612,-11.29616695
-70.22772971,-11.28704986 -70.25438627,-11.29384226 -70.26691,-11.28982364
-70.27306758,-11.29919164 -70.27873452,-11.29459212
-70.27957782,-11.28462448 -70.29115625,-11.28475514 -70.30504215,-11.2797305
-70.07564076,-11.17688037</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></segdi:geom></segdi:conc_maderables4326></gml:featureMember></wfs:FeatureCollection>
As you can see, responses are different in its order and in the number of
its coordinates.
What should I do to show the attributes of a Web Service generated in
Geoserver from a PostGIS Database?
Thanks for the help.
Regards
Darwin Quispe
View this message in context: http://osgeo-org.1560.x6.nabble.com/Issues-with-WMS-GetFeatureInfo-tp5315982.html
Yes it's weird.
Is there any error in the devtools log ?
Could you prodive a public url for your geoserver ?
We need to check when the error happens, if it is in the ol3
getFeatureInfoFormat or after in geonetwork..
You can try to run ol3 getFeatureInfoFormat test over your response to have
an idea.
On Wed, Apr 5, 2017 at 11:13 PM, Darwin <darwinquill@anonymised.com> wrote:
Hello
datastore
in Geoserver).
cases:
amp;typeName=segdi%3AConc_Maderables4326"><gml:
boundedBy><gml:null>unknown</gml:null></gml:boundedBy><gml:
featureMember><segdi:Conc_Maderables4326
gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:
coordinates
N�
amp;typeName=segdi%3Aconc_maderables4326"><gml:
featureMember><segdi:conc_maderables4326
N�
its coordinates.
Regards
Darwin Quispe
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
