[GeoNetwork-users] Java exception error
We are running our GN node on apache tomcat, after installing another
service (geo-server a web feature service) on the same port, the error below
is showing every day forcing us to restart the tomcat server then it
automatically clears, any suggestions on solving this problem?
Stephen Waswa
FAO SWALIM
Nairobi - Kenya
HTTP Status 500 -
  _____
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
root cause
javax.xml.transform.TransformerFactoryConfigurationError: Provider
org.apache.xalan.processor.TransformerFactoryImpl could not be instantiated:
java.lang.NullPointerException
        javax.xml.transform.TransformerFactory.newInstance(Unknown Source)
        jeeves.utils.Xml.transform(Xml.java:119)
        jeeves.utils.Xml.transform(Xml.java:111)
jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:6
98)
jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:466
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:408)
        jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:614)
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:170)
jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:99)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
note The full stack trace of the root cause is available in the Apache
Tomcat/5.5.16 logs.
  _____
Apache Tomcat/5.5.16
Hi Stephen,
Do you know if the Java version you were running changed? Maybe you could provide more of the log file (directly to me if large)?
Ciao,
Jeroen
Stephen Waswa
FAO SWALIM
Nairobi - Kenya
HTTP Status 500 -
  _____
message
exception
root cause
98)
Tomcat/5.5.16 logs.
  _____
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
