[GeoNetwork-users] java.lang.outOfMemoryError
  Hi -
     I have geonetwork 2.4.3.0 installed on Ubuntu running under Jetty. I have only one metadata record. If I try to edit the metadata record more than once or twice, I get this
java.lang.OutOfMemoryError: requested 2147483656 bytes for Chunk::new. Out of swap space?
Looks like it is requesting a 2 gig chunk for editing a small metadata record. Has anybody seen this before, and more to the point, how do I cure this?
Garey Mills
Library Systems Office
UC Berkeley
That number (2147483656) is suspiciously close to the limit for a signed
32 bit number (2,147,483,647). Beyond pointing that out I'll leave it for
the devs.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
