[GeoNetwork-users] Java Memory Errors?
I'm a Desktop Support Tech, and I've been asked to upgrade my company's installation of GeoNetworks.
We currently have a much older version and want to go to 3.0.4.
I hadn't realized that the model had changed from local exe to local (tomcat?) server-based.
Every attempt to run the startup batch file has failed; it never gets far enough to start the server.
Also, I'm not trained in Java at all, so it's been an uphill battle so far.
I've narrowed everything down to OutofMemory errors, but I currently have the Java heap size set to -Xmx1536m.
Something doesn't seem right; does it really need more than that?
(I did try 2g, but it failed miserably; Java exception right away.)
What am I missing here?
Joseph Mullin | Desktop Support Analyst | Unity Health Insurance | Gundersen Health Plan | Quartz(r)
joe.mullin@anonymised.com | Ph. 608.644.3493 | Unityhealth.com<https://unityhealth.com/&gt; | QuartzASO.com<https://quartzaso.com/&gt; Gundersenhealthplan.org<https://www.gundersenhealthplan.org/&gt;
840 Carolina Street | Sauk City, Wisconsin 53583-1374
This electronic message is intended only for the use of the addressee(s) named above and may contain confidential information.
If you are not the intended recipient of this message, you are notified that any dissemination, distribution or copying of this message is strictly prohibited.
If you received this message in error, please immediately notify the sender by telephone or email and return the original message by email to the sender.
Thank you for your cooperation.
