[GeoNetwork-users] java.security.AccessControlException
hi all,
I am new to both setting up a tomcat server and geonetwork. I
successfully set up tomcat but when I try to access geonetwork I get
the following error message. Operating system is ubuntu linux 9.10.
tomcat 6. geonetwork 2.4.3.
Below is the error message. Any ideas as to what could be wrong?
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented
it from fulfilling this request.
exception
javax.servlet.ServletException: Exception raised
         jeeves.server.JeevesEngine.init(Unknown Source)
         jeeves.server.sources.http.JeevesServlet.init(Unknown Source)
         javax.servlet.GenericServlet.init(GenericServlet.java:212)
         sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
         sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
         sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
         java.lang.reflect.Method.invoke(Method.java:616)
         org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:269)
         java.security.AccessController.doPrivileged(Native Method)
         javax.security.auth.Subject.doAsPrivileged(Subject.java:537)
         org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:301)
         org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
         org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:115)
         org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
         org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
         org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
         org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
         org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
         java.lang.Thread.run(Thread.java:636)
root cause
java.security.AccessControlException: access denied
(java.io.FilePermission
/var/www/geonetwork/web/geonetwork/../../data/tmp read)
         java.security.AccessControlContext.checkPermission(AccessControlContext.java:342)
         java.security.AccessController.checkPermission(AccessController.java:553)
         java.lang.SecurityManager.checkPermission(SecurityManager.java:549)
         java.lang.SecurityManager.checkRead(SecurityManager.java:888)
         java.io.File.exists(File.java:748)
         java.io.File.mkdirs(File.java:1195)
         jeeves.server.JeevesEngine.initGeneral(Unknown Source)
         jeeves.server.JeevesEngine.loadConfigFile(Unknown Source)
Hi Jan
The problem is that tomcat security manager is enabled by default in ubuntu
and is quite restrictive.
If is secure for you disabling it, check this
http://hiden.org/sysadmin/tomcat-5-5-and-ubuntu/, otherwise you'll need to
configure the permissions for the path
(/var/www/geonetwork/web/geonetwork/../../data/tmp) in the security manage
(check tomcat documentation).
Jose Garcia
On Fri, Jul 16, 2010 at 11:05 AM, Jan <fire@anonymised.com> wrote:
hi all,
HTTP Status 500 -
message
exception
root cause
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
GeoNetwork-users mailing list
Thank you very much Jose. You were absolutely right. Now that the setup is completed I can start experimenting with the application itself.
Jan
jose garcia schrieb:
Hi Jan
The problem is that tomcat security manager is enabled by default in ubuntu and is quite restrictive.
If is secure for you disabling it, check this http://hiden.org/sysadmin/tomcat-5-5-and-ubuntu/, otherwise you'll need to configure the permissions for the path (/var/www/geonetwork/web/geonetwork/../../data/tmp) in the security manage (check tomcat documentation).
Jose Garcia
On Fri, Jul 16, 2010 at 11:05 AM, Jan <fire@anonymised.com <mailto:fire@anonymised.com>> wrote:
    hi all,
    HTTP Status 500 -
    message
    exception
    root cause
    Visit sprint.com/first <http://sprint.com/first&gt; --
    <mailto:GeoNetwork-users@lists.sourceforge.net>
