[GeoNetwork-users] Javascript/CSS Issue
Trying to upgrade to version 2.10.2 and having issues getting the JS and CSS to work. I am trying to install on Windows machine and using jetty server. The instructions to build javascript from the documentation are:
* Python and closure - To build Javascript:
sudo easy_install http://closure-linter.googlecode.com/files/closure_linter-latest.tar.gz cd /path/to/closure-library-parent-dir git clone http://code.google.com/p/closure-library/ cd closure-library wget http://closure-compiler.googlecode.com/files/compiler-latest.zip unzip compiler-latest.zip
How do I do this on windows machine?
2014-03-04 17:33 GMT+01:00 Faris, Melvin T. <mfaris@anonymised.com>:
sudo easy_install
http://closure-linter.googlecode.com/files/closure_linter-latest.tar.gzcd /path/to/closure-library-parent-dir git clone
compiler-latest.zip
There is no closure dependency in 2.10.x (and not anymore in develop branch)
https://github.com/geonetwork/core-geonetwork/tree/2.10.x
You should be able to build the application following
http://geonetwork-opensource.org/manuals/2.10.3/eng/developer/development/index.html#build-geonetwork
Where did you get those instructions ? maybe some README file needs to be
updated.
HTH.
Francois
Subversion Kills Productivity. Get off Subversion & Make the Move to
Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and
the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
