[GeoNetwork-users] Javascript
Hi all
My metadata entry requires the display of > 1 map - I have tried very hard to use extant code but this will only display the first map and any subsequent ones aren't visible (I'm processing the various instances of gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox
with a copy of the iso19139 template which uses the extentViewer css class.
So I was wondering - how do I get my metadata.xsl stylesheet to fire up some javascript when search results are returned? That way I can access OpenLayers directly...
If my schema is called iso19139mim will this be something to do with the "iso19139mim.javascript" template?
Thanks
Paul
Paul Cleverley
Software Developer, Hydrodynamics & Metocean
E: p.cleverley@anonymised.com<mailto:p.cleverley@anonymised.com>
T: +44 (0)1491 822483
<http://www.hrwallingford.com/banner.html&gt;
[HR Wallingford Logo]
HR Wallingford
Howbery Park, Wallingford, Oxfordshire OX10 8BA, United Kingdom
T: +44 (0)1491 835381 F: +44 (0)1491 832233
[HR Wallingford Secondary Logo]
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Hi Paul,
2014-08-11 14:58 GMT+02:00 Paul Cleverley <P.Cleverley@anonymised.com>:
Hi all
iso19139 schema support multiple bbox, so you should call iso19139 template
for it or do something like
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/present/metadata-geo.xsl#L94
in your schema.
class.
If you're using the Ext.js interface, then you should look to the
EditorPanel (
https://github.com/geonetwork/core-geonetwork/blob/develop/web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/editor/EditorPanel.js#L962)
and the metadataUpdated event maybe.
HTH
Francois
Thanks
Paul
Paul Cleverley
HR Wallingford
GeoNetwork-users mailing list
Thanks Francois,
I’m not using the Ext.js interface I’m afraid – that would be just one Javascript framework too far for my poor little brain :smiling_face:
I have derived templates from iso19139 (so I can use my own styles – can’t get that to work any other way) but my derived templates don’t allow multiple maps – and by “maps” I mean multiple divs on a single page with different backgrounds, layers, zoom levels etc etc.
I’m beginning to wonder if I’m not too old for this…:-}
Paul
Sent: Monday, August 11, 2014 2:41 PM
To: Paul Cleverley
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Javascript
Hi Paul,
2014-08-11 14:58 GMT+02:00 Paul Cleverley <P.Cleverley@...1309...<mailto:P.Cleverley@…1309…>>:
Hi all
iso19139 schema support multiple bbox, so you should call iso19139 template for it or do something like
in your schema.
If you're using the Ext.js interface, then you should look to the EditorPanel (https://github.com/geonetwork/core-geonetwork/blob/develop/web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/editor/EditorPanel.js#L962) and the metadataUpdated event maybe.
HTH
Francois
Thanks
Paul
Paul Cleverley
E: p.cleverley@...1309...<mailto:p.cleverley@…1309…><mailto:p.cleverley@…1309…>
HR Wallingford
www.hrwallingford.com<http://www.hrwallingford.com>
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
This message has been scanned for viruses by MailControl<http://www.mailcontrol.com/&gt;, a service from BlackSpider Technology
Click here<https://www.mailcontrol.com/sr/b9vUdtpCx9zGX2PQPOmvUgny0!6zNmYYd+ZeZhwiMXjzNq1iPg5g1waVP+PmbJ2niUxN!gnS1L2VGm43FW9a3A==&gt; to report this email as spam.
2014-08-11 15:56 GMT+02:00 Paul Cleverley <P.Cleverley@anonymised.com>:
Thanks Francois,
So which GeoNetwork version are you using ? Maps are initialized by this JS
function
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/scripts/geo/extentMap.js#L80
brain J
The editor will generate one map per boundingbox (but background maps and
layers will be the same).
Cheers.
Francois
Paul
*From:* Francois Prunayre [mailto:fx.prunayre@anonymised.com]
*Sent:* Monday, August 11, 2014 2:41 PM
*To:* Paul Cleverley
*Cc:* geonetwork-users@lists.sourceforge.net
*Subject:* Re: [GeoNetwork-users] Javascript
Hi Paul,
> Hi all
in your schema.
class.
EditorPanel (
HTH
Francois
> Thanks
> Paul
> Paul Cleverley
> HR Wallingford
Click here
*HR Wallingford and its subsidiaries* uses faxes and emails for
I’m using version 2.10.3 on Windows 2012 Server
Here is the HTML resulting from two of my instances
<div class="extentViewer" style="margin:auto; width:98%;" id="ext-gen684" edit="false" target_polygon="" watched_bbox="w,s,e,n" elt_ref="" mode="bbox">
<div class="extentViewer" style="margin:auto; width:98%;" id="d308e73864" edit="false" target_polygon="" watched_bbox="wd308e73864,sd308e73864,ed308e73864,nd308e73864" elt_ref="d308e73864" mode="bbox">
<div class="extentViewer" style="margin:auto; width:98%;" id="d308e74185" edit="false" target_polygon="" watched_bbox="wd308e74185,sd308e74185,ed308e74185,nd308e74185" elt_ref="d308e74185" mode="bbox">
The first one displays ok – the latter two don’t unfortunately and I can’t figure out why.
Paul
Sent: Monday, August 11, 2014 3:09 PM
To: Paul Cleverley
2014-08-11 15:56 GMT+02:00 Paul Cleverley <P.Cleverley@...1309...<mailto:P.Cleverley@…1309…>>:
Thanks Francois,
So which GeoNetwork version are you using ? Maps are initialized by this JS function https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/scripts/geo/extentMap.js#L80
The editor will generate one map per boundingbox (but background maps and layers will be the same).
Cheers.
Francois
Paul
To: Paul Cleverley
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hi Paul,
Hi all
in your schema.
HTH
Francois
Thanks
Paul
Paul Cleverley
T: +44 (0)1491 822483<tel:%2B44%20%280%291491%20822483>
HR Wallingford
T: +44 (0)1491 835381<tel:%2B44%20%280%291491%20835381> F: +44 (0)1491 832233<tel:%2B44%20%280%291491%20832233>
Click here<https://www.mailcontrol.com/sr/MZbqvYs5QwJvpeaetUwhCQ==&gt; to report this email as spam.
2014-08-11 16:41 GMT+02:00 Paul Cleverley <P.Cleverley@anonymised.com>:
mode="bbox">
figure out why.
Maybe you should add a breakpoint in the browser debugger here
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/scripts/geo/extentMap.js#L89
and check what is happening ?
Cheers.
Francois
Paul
*Sent:* Monday, August 11, 2014 3:09 PM
Thanks Francois,
JS function
brain J
Cheers.
Francois
Paul
Hi Paul,
> Hi all
in your schema.
class.
EditorPanel (
HTH
Francois
> Thanks
> Paul
> Paul Cleverley
> HR Wallingford
Click here <https://www.mailcontrol.com/sr/MZbqvYs5QwJvpeaetUwhCQ==&gt; to
