[GeoNetwork-users] JDBC Conection failed
Dear Geonetwork Users,
My name Winarno from Indonesia new geonetwork user.
I Install Geonetwork on my Server and so far running well. But i have
problem, every morning when i want searching metadata, i get error like JDBC
conection failed. And then when i restart Tomcat the problem solve. and I
have to restart Tomcat every morning.
Any idea for solve my problem ?
Winarno
Dear Winarno,
Maybe your JDBC connection pool (if you have one) is exhausted.
Are there any messages in the logs of Tomcat?
If this is the case, you may want to set up Tomcat to recycle idle connections after a certain time.
This is one of the properties of your JDBC connector, if I'm not mistaken. I can't really give you any more details, though.
Tim
From: "Winarno Makmur Jaya" <neowinarno@anonymised.com>
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] JDBC Conection failed
Date: Thu, 22 Mar 2007 10:34:35 +0700
Winarno
opinions on IT & business topics through brief surveys-and earn cash
GeoNetwork-users mailing list
_________________________________________________________________
All things trendy for Windows Live Messenger ... http://entertainment.msn.be/funwithmessenger
Dear Winarno,
My 1 pence advice:
The cause may be that mysql drops the connection after some time (I
think 8 hours) if there is no activity.
You can use the <reconnectTime> parameter of the mysql database
resource in the config.xml file to force a reconnection if more than
a given time elapsed since last activity. For instance, the following
entry forces a reconnection after one hour:
            <resource enabled="false">
                  <name>main-db</name>
                  <provider>jeeves.resources.dbms.DbmsPool</provider>
                  <config>
                        <user>admin</user>
                        <password>admin</password>
                        <driver>com.mysql.jdbc.Driver</driver>
<url>jdbc:mysql://$WEBSERVER_HOST/geonetwork</url>
                        <poolSize>4</poolSize>
                        <reconnectTime>3600</reconnectTime>
                  </config>
            </resource>
Stephen Waswa
FAO-SWALIM
Nairobi,
Kenya.
On 3/22/07, Tim Jacobs <jacobs_tim100@anonymised.com> wrote:
Dear Winarno,
I
Tim
>JDBC
>Thanks,
>Winarno
>your
your
Stephen B. Waswa
Somalia Water and Land Information Management System,
Food and Agriculture Organization of the United Nations,
P.O. Box 30470 -00100 Nairobi (Kenya)
Office:
3rd Floor Kalson Tower, Crescent Road,
Parklands, Nairobi
Tel: + 254 20 3743464
Fax: +254 20 3743498
Cellphone +254 721 826 320
e-mail: swaswa@anonymised.com
           waswabs@anonymised.com
           www.faoswalim.org
