HI Emmanuel,
Thanks for the suggestion. If I've understood your email
correctly, you're suggesting changing the jetty.xml file line jetty.host
to the following:
name="jetty.host" default="*"/>
For me at least this causes jetty to not even start - it gives me
a series of errors about unresolved addresses. Can you clarify this is
what you meant?
Jonathan Moules
GIS Developer.
Warwickshire Observatory,
Warwickshire County Council.
01926 412358
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
