[GeoNetwork-users] Join translation team
Hi!
I would like to offer Slovenian translations on my Geonetwork instance. I wanted to download the translation files from the Transifex portal, but I can’t since I’m not part of the translation team and I didn’t get any response after clicking the “Join team” button a week ago.
On StackExchange (https://gis.stackexchange.com/questions/276904/geonetworks-languages/281852?noredirect=1#comment475338_281852), I got a suggestion to ask for translations access on the users or developers mailing list and this email is me asking to allow me to join the translators team or to share me the existing Slovenian translation files. As stated above, my main interest is to offer the visitors of my geonetwork instance to see the page in Slovenian, however, I can probably also help further translate the missing parts.
Finally, why are GeoNetwork decision makers making it so hard to access translation files for languages not fully translated? On the Transifex project page (https://www.transifex.com/geonetwork/core-geonetwork/) should be a not that we must ask for access on the mailing list instead of clicking the "Join team” button. I’ve already spent way too much time for this and I still don’t know wether I’ll get those files or not. I would rather spend this time translating the missing parts …
Sorry for my rants :frowning:
Thank you and kind regards,
Marko
Thanks for adding me to the translators team! I’ve already made some translations :slight_smile:
However, now I have a problem applying the downloaded translations (Angular UI* ones, marked "for use") to my running GeoNetwork instance (v3.4.3.0). I made the changes as advised in the guide https://geonetwork-opensource.org/manuals/3.4.x/is/contributing/translating.html and adjusted the file paths:
- instead of web-ui/src/main/resources/catalog/locales I added the translations to /var/lib/jetty9/webapps/geonetwork/catalog/locales/
- I’ve renamed the translation files on the upper path to conform with existing file names (to sl-admin.json, sl-core.json, sl-editor.json and sl-search.json)
- instead of web-ui/src/main/resources/catalog/js/CatController.js, I’ve registered the new language in /var/lib/jetty9/webapps/geonetwork/catalog/js/CatController.js
The parts in CatController.js that I’ve modified (I wanted to hide other translations, with the exception of English):
  module.constant('gnLangs', {
    langs: {
        'eng': 'en',
        'slv': 'sl'
$scope.langLabels = {'eng': 'English', 'slv': 'Slovenščina’};
After restarting Jetty, the language selector in my GeoNetwork instance offers “English” and “undefined”. If I choose “undefined”, the URL changes to “slv” language, but all the strings on the page still remain in English.
Not sure what I’m doing wrong ... would anyone care to help me get the Slovenian translations work?
Marko
On 17 Sep 2018, at 18:22, Marko Praprotnik <marko.praprotnik@anonymised.com <mailto:marko.praprotnik@anonymised.com>> wrote:
Hi!
Marko
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@anonymised.comrceforge.net>
Hi Marko
In the UI settings currently is possible to configure the list of languages
to display, you can remove the unwanted ones and add new ones.
http://SERVER/geonetwork/srv/eng/admin.console#/settings/ui
For the translation, I think you need to add in XX-core.json files a key
with the iso 3 code
"slv": "Slovenščina"
Jose García
On Tue, Sep 18, 2018 at 10:04 AM, Marko Praprotnik <marko.praprotnik@anonymised.com1...
contributing/translating.html <https://geonetwork-
opensource.org/manuals/3.4.x/is/contributing/translating.html> and
sl-search.json)
    langs: {
        'eng': 'en',
        'slv': 'sl'
Marko
> Hi!
geonetworks-languages/281852?noredirect=1#comment475338_281852 <
geonetworks-languages/281852?noredirect=1#comment475338_281852>), I got a
project page (https://www.transifex.com/geonetwork/core-geonetwork/ <
https://www.transifex.com/geonetwork/core-geonetwork/&gt;\) should be a not
> Marko
lists.sourceforge.net>
projects/geonetwork
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Thank you, Jose, I did as you suggested:
- set the languages in Admin console > Settings > User interface (added slv = sl and removed other languages) .. I’ve already tried this before sending the first request for help
- I renamed the translation files in geonetwork/catalog/locales/sl-*.json to slv-*.json
But, nothing seems to be changed, everything is still in English and the language selector still shows “undefined” instead of Slovenščina. Maybe I already messed up my configuration, will need to retry with a clean instance. Will report back when I finish this.
Thanks again,
Marko
Marko Praprotnik / Research / +386-40-858-424
XLAB d.o.o. / Pot za Brdom 100 / SI - 1000 Ljubljana / Slovenia
tel.+386 1 244 77 50 / info@anonymised.com / www.xlab.si <https://www.xlab.si/?lang=en&gt;
On 18 Sep 2018, at 10:43, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Marko
In the UI settings currently is possible to configure the list of languages to display, you can remove the unwanted ones and add new ones.
For the translation, I think you need to add in XX-core.json files a key with the iso 3 code
Jose García
On Tue, Sep 18, 2018 at 10:04 AM, Marko Praprotnik <marko.praprotnik@anonymised.com701... <mailto:marko.praprotnik@anonymised.com>> wrote:
However, now I have a problem applying the downloaded translations (Angular UI* ones, marked "for use") to my running GeoNetwork instance (v3.4.3.0). I made the changes as advised in the guide https://geonetwork-opensource.org/manuals/3.4.x/is/contributing/translating.html <https://geonetwork-opensource.org/manuals/3.4.x/is/contributing/translating.html&gt; and adjusted the file paths:
    langs: {
        'eng': 'en',
        'slv': 'sl'
Marko
> On 17 Sep 2018, at 18:22, Marko Praprotnik <marko.praprotnik@anonymised.com <mailto:marko.praprotnik@anonymised.com> <mailto:marko.praprotnik@anonymised.com>> wrote:
> Hi!
> On StackExchange (https://gis.stackexchange.com/questions/276904/geonetworks-languages/281852?noredirect=1#comment475338_281852 <https://gis.stackexchange.com/questions/276904/geonetworks-languages/281852?noredirect=1#comment475338_281852&gt;\), I got a suggestion to ask for translations access on the users or developers mailing list and this email is me asking to allow me to join the translators team or to share me the existing Slovenian translation files. As stated above, my main interest is to offer the visitors of my geonetwork instance to see the page in Slovenian, however, I can probably also help further translate the missing parts.
> Finally, why are GeoNetwork decision makers making it so hard to access translation files for languages not fully translated? On the Transifex project page (https://www.transifex.com/geonetwork/core-geonetwork/ <https://www.transifex.com/geonetwork/core-geonetwork/&gt;\) should be a not that we must ask for access on the mailing list instead of clicking the "Join team” button. I’ve already spent way too much time for this and I still don’t know wether I’ll get those files or not. I would rather spend this time translating the missing parts …
> Marko
> GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@anonymised.comourceforge.net> <mailto:GeoNetwork-users@lists.sourceforge.net>
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664 <tel:+31318416664>
<https://www.facebook.com/geocatbv&gt; <https://twitter.com/geocat_bv&gt; <https://plus.google.com/u/1/+GeocatNetbv/posts&gt;
Please consider the environment before printing this email.
