seems GN uses the EXTJS v3.2.1, as far as I could search through the developer/user forum. checked the documents in ExtJs 3.2, and fixed the problem. could not use 'new Ext.data.HttpProxy'. removed it, and used 'url: myurl', which made it working.
To: "geonetwork-users@lists.sourceforge.net" <geonetwork-users@anonymised.comeforge.net>
Sent: Tuesday, February 10, 2015 10:35 AM
Subject: Re: JsonStore problem
I moved one step forward. In the XXXStore.js, after adding "new Ext.data.HttpProxy" after the 'proxy:', the data service could be successfully called, as I found it called in Firebug, and the json response. But it is only half the story. In the callback function, I could catch the 'success' is true, but the 'records' is empty, which means there is no data returned from the callback function. Here are my code:
XXXStore.jsGeoNetwork.data.XXXStore = function(myurl) {return new Ext.data.JsonStore( { storeId: 'mystore',
proxy: new Ext.data.HttpProxy({
method: 'GET',
url: myurl, reader: { type: 'json', root: 'results' } }),
fields: ['myid', 'myname'],
idProperty: 'myid', listeners: { load: function(store, records, success) {
if (success) {
alert("Store found: " + records.length);
} else {
alert("Store Failed");
In the 'generateAdvanceSearchForm' function within SearchApp.js,I do the following: var myurl = 'http://localhost:8080/examples/jsp/getmylist.jsp’;
var store = new GeoNetwork.data.XXXStore(myurl); store.load ({ scope: this,
callback: function (records, options, success) {
if (success) {
alert("Callback have: " + records.length);
} else {
alert("Callback Failed");
When I load the page 'http://localhost:8080/geonetwork/srv/eng/search?debug=true’, I got the alert 'Store found: 0' and the 'Callback have: 0'.
Since I saw the 'getmylist.jsp' is called, I guess it might be a scope issue? If it is, how should I fix this?
appreciate any help on it.
Sent: Thursday, February 5, 2015 2:07 PM
Subject: JsonStore problem
I am new to GN. A problem bugged me for a few days now, and would like to ask for your help.
I have created a json store "XXXStore.js" to return a json object by calling from a HTML page. It can work fine when I tested outside GeoNetwork app.
Then I put the 'XXXStore.js' under 'apps/js/GeoNetwork/lib/GeoNetwork/data/'. Here is how I did it:
1.) In "GeoNetwork.js", I added an entry "GeoNetwork/data/XXXStore.js" together with other GN stores scripts.
2.) In "SearchFormTools.js", I added a function "getXXXField()", which will call the "GeoNetwork.data.XXXStore(url)": xxxStore = GeoNetwork.data.XXXStore(url); xxxStore.load();
3.) In SearchApp.js, I added a checkbox group to populate data from the store.
Unfortunately, it looks the json store failed to be created. In Firebug, I caught that "xxxStore" is undefined.
Do I missed any step I need to add within GeoNetwork app? Why does it works outside GeoNetwork, but failed within GeoNetwork? Guess GN needs some extra setting?
any help is much appreciated.
Yan
