[GeoNetwork-users] Keywords field
Hi all
I've just installed GN v2.1 and I tried to create a new metadata like a
trial. So, when I want to fill the "keywords" field this doesn't appear,
just this description:
::Keywords
Theme ()
Place ()
Stratum ()
Temporal ()
Then, it isn't editable. In want to know if the problem is a configuration
or what is wrong.
gchamorro
Hello gchamorro,
You want to fill in the keyword field and you can't ?
I am not sure to understand.
What is the template you use to create your metadata trial ?
Usually on the descriptive keyword part is compose of two part :
The keywords : (Free text field that can come from Thesaurus, multiple
instance are possible)
And the Type part : (Theme, Place, Stratum, Temporal)
You do not see the keyword part ?
If you click on the [+] near the last "descriptive keyword" element the new
"descriptive keyword "created has the same problem ?
If you go to the xml view the keyword part must look like that :
<gmd:descriptiveKeywords>
  <gmd:MD_Keywords>
    <gmd:keyword>
      <gco:CharacterString/>
    </gmd:keyword>
    <gmd:keyword>
    </gmd:keyword>
    <gmd:keyword>
    </gmd:keyword>
    <gmd:type>
      <gmd:MD_KeywordTypeCode codeList="" codeListValue="discipline"/>
    </gmd:type>
  </gmd:MD_Keywords>
</gmd:descriptiveKeywords>
Here a descriptive keyword with 3 keyword field and the type.
http://www.nabble.com/file/p14331720/desckey.jpg
Fabien.
Giovanna Chamorro wrote:
Hi all
::Keywords
Theme ()
Place ()
Stratum ()
Temporal ()
or what is wrong.
gchamorro
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services
for just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Keywords-field-tp14320040s18419p14331720.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
