I'm starting to play with GeoNetwork and found and issues with the
available languages, hopefully it's not something obvious that I
missed.
I'm running GeoNetwork 2.10.3, which I installed from a WAR under
Tomcat6 in Ubuntu 12.04, using Postgres as the DB backend
After following the install instructions, the web app loads fine but
when trying to configure the CSW service (at Administration >
Catalogue Settings > CSW server configuration), the language field
dropdown appears empty:
http://i.imgur.com/hOAxaGj.png
The GetCapabilities request returns a "Cannot load/process
capabilities" exception because of this (full stacktrace [1])
Same for the language dropdowns at Administration > Localization:
http://i.imgur.com/a4ujZke.png
The dropdown for changing the general GUI language does list a dozen
or so languages:
http://i.imgur.com/0aJCjzj.png
Do I need to enable the languages manually somor did I miss some steps?
Thanks very much for your help
Adrià
[1] https://gist.github.com/amercader/9325196
To reply my own email and in case someone finds the same issue, I
could not see the languages because I haven't run manually the
following SQL script:
/var/lib/tomcat7/webapps/geonetwork/WEB-INF/classes/setup/sql/data/loc-eng-default.sql
Now it works great,
Adrià
On 3 March 2014 14:29, Adrià Mercader <adria.mercader@anonymised.com> wrote:
missed.
or so languages:
Adrià
