I have a geonetwork installed and I want to change the numbers of
languages.
I want to show just port and english. I have changed config.gui.xml, but
nothing have changed. I am using html5 ui. Is there another place that I
have to change to remove the languages?
I have the same problem over here. The html5gui shows languages which should
not bei shown any longer.
I have also changed strings.xml for the two languages I want to use
(/srv/tomcat/geonetwork/webapps/geonetwork/loc/language/xml/strings.xml - Be
careful with strings.xml. It has to be a valid xml-file with the right
encoding.)
Problem is the same in GeoNetwork 2.10.4. The "useless" languages stay
visible in the "new" gui all of the time. The older gui works fine.
