Jeroen,
Just downloaded the RC2 release and tried it out. I'm very keen to use this
release as it has some great new features for import and harvesting.
I do have a problem accessing the harvesting page. I get a blank page and
the following error message in the console. I'm guessing I'm getting a nill
return from the harvesting.
Is there anything I need to set up? I'm running on localhost with MySQL
straight out the box.
Many thanks
Peter
Console output follows:
191672 [16713087@anonymised.com] INFO jeeves.request -
191672 [16713087@anonymised.com] INFO jeeves.request - HTML Request (from
127.0.0.1) :
/geonetwork/srv/en/harvesting
191672 [16713087@anonymised.com] DEBUG jeeves.request - Method : GET
191672 [16713087@anonymised.com] DEBUG jeeves.request - Content type : null
191672 [16713087@anonymised.com] DEBUG jeeves.request - Accept :
image/png,image/
*;q=0.8,*/*;q=0.5
191672 [16713087@anonymised.com] DEBUG jeeves.request - Session id is 1516pjk9zdk32
191672 [16713087@anonymised.com] INFO jeeves.service - Dispatching : harvesting
191672 [16713087@anonymised.com] DEBUG jeeves.service - -> no input parameters
191672 [16713087@anonymised.com] INFO jeeves.service - -> dispatching to output
for
: harvesting
191719 [16713087@anonymised.com] INFO jeeves.service - -> transforming with
styles
heet : C:\geonetwork\web\geonetwork/xsl/harvesting/harvesting.xsl
Recoverable error on line 15 of
file:/C:/geonetwork/web/geonetwork/xsl/main.xsl:
XTRE0540: Ambiguous rule match for /
Matches both "document-node()" on line 21 of
file:/C:/geonetwork/web/geonetwork/xsl/harvesting/harvesting.xsl
and "document-node()" on line 34 of
xsl
191828 [16713087@anonymised.com] INFO jeeves.service - -> end transformation
for :
harvesting
191828 [16713087@anonymised.com] INFO jeeves.service - -> output ended for :
harvest
ing
191828 [16713087@anonymised.com] INFO jeeves.service - -> dispatch ended for :
harvest
ing
Jeroen.Ticheler wrote:
Dear all,
It is a pleasure to announce the last release candidate for GeoNetwork
opensource. In Bolsena, Italy we had some excellent work done, fixing
a wide range of bugs and making some solid performance improvements. I
hope you will be able to do some good testing of this release
candidate, after which we will release the Final version in two weeks
from now.
The v2.4.0RC2 can be downloaded here:
https://sourceforge.net/projects/geonetwork/files/
Big thanks to all contributors and testers,
Greetings,
Jeroen
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full
prize
details at: http://p.sf.net/sfu/blackberry
GeoNetwork-devel mailing list
View this message in context: http://n2.nabble.com/Last-release-candidate-(RC2)-available-for-GeoNetwork-opensource-v2.4.0-tp3218787p3221781.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
