Hello! I installed Linux CentOS 2.8 in Geonetwork, and I have a strange
problem. Layers that are inside the folder of the main map overlays, are
multiplying. Each time soon in Geonetwork Layers are organized more
replicated. Already checked the configuration of the layers in the file
config-GUI.xml and everything is normal. Can anyone help?
Thank you.
Davi de O. Custódio
I also have the same problem (Geonetwork 2.8.0). Did you find any solution?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layers-Replied-on-Overlay-Folder-tp5041329p5057897.html
Leonidas, unfortunately no one answered. I'm suspicious of this forum,
because I have done several questions and got no answer yet. Is this group
alive?
On Tue, Jun 4, 2013 at 4:27 PM, leonidas <leonidas_liakos@anonymised.com> wrote:
How ServiceNow helps IT people transform IT departments:
1. A cloud service to automate IT design, transition and operations
2. Dashboards that offer high-level views of enterprise services
3. A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
GeoNetwork-users mailing list
Davi de O. Custódio
Yes the group is alive, maybe there is no answer yet for our problem. We can
also try to ask at http://gis.stackexchange.com
<http://gis.stackexchange.com> .
I run geonetwork as war inside tomcat6...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layers-Replied-on-Overlay-Folder-tp5041329p5057917.html
hi Leonidas,
this list has received 261 messages in the past 365 days. Of those, 116
received 0 replies - so your chance of getting a reply is about 56%.
There may be room for improvement there, but the list is certainly not
"dead".
You might also consider mailing to the GeoNetwork developer's list or to
the French or Spanish users' lists if you speak your languages. Though
cross-posting is of course frowned-upon; you might also try re-posting to
this users' list if you have no reply after some time -- maybe one of the
few people who could answer you missed the first time.
Note that unlike some other open source projects. there is no Big Company
sponsoring GeoNetwork development or mailing list answers. People do their
best if they can help you; and this is all voluntarily, spare-time effort.
Kind regards,
Heikki Doeleman
On Tue, Jun 4, 2013 at 10:09 PM, leonidas <leonidas_liakos@anonymised.com> wrote:
can
Hi David and Leonidas
I could reproduce the issue and checking for a fix. Asap as I get it
working will commit and will inform you.
Jose García
On Tue, Jun 4, 2013 at 10:18 PM, heikki <tropicano@anonymised.com> wrote:
hi Leonidas,
"dead".
Kind regards,
Heikki Doeleman
> can
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Jose, thank you!!!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layers-Replied-on-Overlay-Folder-tp5041329p5057987.html
I have finally managed to authenticate using AD authentication with our
Geoportal 1.2.2 installation.
My next step is to try and register the WMS services on our internal
ArcGIS 10.0 server.
When following these instructions
1. Log in to your geoportal. Click Administration. Click Add. Make sure
Register resource on the network is selected and click Proceed.
2. Select Protocol Type ArcGIS.
3. In REST URL, type http://<<internal GIS Server>>/ArcGIS/rest/services/.
4. In SOAP URL, type http://<<internal GIS Server>>/ArcGIS/services/.
5. In title, type Services from <<internal GIS Server>>.
Click Test to verify the connection. A green banner with "Connection
successfully verified" should appear.
Test does not work. I get "Unable to connect to host."
I then click the save button and receive the following error in the
gpt.*.log
INFO: No credentials available for NTLM <any
realm>@arcgisserverdev.dpi.nsw.gov.au:80
Jun 05, 2013 3:47:56 PM com.esri.gpt.framework.jsf.BaseActionListener
handleException
SEVERE: Exception raised.
com.esri.arcgisws.runtime.exception.ArcGISWebServiceException: HTTP status
code {401 - Unauthorized} received from server
I am logged in as myself which has admin access to to GIS server. I can
see that my credentials are not passed through to our internal GIS Server.
Any help is greatly appreciated.
Toby Te Rupe B.Sc, Dip Info Sc | Senior Software Support Analyst |
Information & Communications Technology
NSW Trade & Investment
161 Kite St | Orange NSW 2800 | Locked Bag 21 | Orange NSW 2800
W: 02 6391 3275 | F: 02 6391 3290 | M: 0424 890 761 | E:
toby.terupe@anonymised.com
W: www.trade.nsw.gov.au | www.dpi.nsw.gov.au
This message is intended for the addressee named and may contain confidential information.
If you are not the intended recipient, please delete it and notify the sender.
Views expressed in this message are those of the individual sender, and are not necessarily the views of their organisation.
Hi
It's fixed (see https://github.com/geonetwork/core-geonetwork/issues/116).
Next release will contain the fix.
Jose García
On Wed, Jun 5, 2013 at 7:52 AM, leonidas <leonidas_liakos@anonymised.com> wrote:
Jose, thank you!!!
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Thank you! I built it from source and it works with no problems!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Layers-Replied-on-Overlay-Folder-tp5041329p5058178.html
