Uid attribute : "uid"
question : is it the filter for searching the name of one person as he
gives his user and password login ?
IIRC, the LDAP GeoNetwork will function this way :
"I'm user pmauduit, and I try to authenticate using pmauduit/secret on
GeoNetwork", the GN will look for 'uid=pmauduit,....' into the LDAP tree" ;
I think GeoNetwork will use the regular userPassword attribute for password
check. You could have used "cn" attribute, depending on your LDAP setup.
Distinguished names
Base : dc=gov,dc=pf
Question , is it where to search the root first ?
User : ou=person
Question, is it where users belong in a group ?
I think GN will try to lookup your current users into
"ou=person,dc=gov,dc=pf", right. But I'm pretty sure (long time that I've
not toyed around with LDAP / GeoNetwork) that the "group" notion from the
LDAP is disconnected from the one into GeoNetwork.
These 3 last parameters are for searching in the ldap tree users ?
i have test these parameters and , i conclude that when a person login,
he must belong within the group "person" , whom belong to the
"dc=gov,dc=pf" with a DN uid=xxx,ou=person,dc=gov,dc=pf
Am i right ?
I guess so ; the last parameter ("profile") is used to store the profile of
your users on the LDAP side. i.e. if profile attribute == Admin, then your
user is admin on GN, if == Reviewer, then he is reviewer, etc...
When the ldap authentication succeed , one row in the user table
(postgres) is created with the User's attributes parameters respectively
in the columns name and profile.
Right, there is a kind of synchronisation, since the user successfully
connected the first time is then copied into the postgresql user table. But
I guess you will have to connect as administrator in order to correctly
affect your users to your GeoNetwork groups (since as I said, the two
notions - ldap groups vs geonetwork groups - are disconnected).
Hth,
Pierre Mauduit
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)4 79 44 44 92
http://www.camptocamp.com
pierre.mauduit@anonymised.com
