[GeoNetwork-users] Log file (geonetwork.log) flooded with warning message
Dear Geonetwork Developers,
I am running geonetwork 2.7 more than 1 years. But in recent days, the log file (geoentwork.log) flooded with warning message even I restarted the application:
2012-10-03 00:00:01,645 WARN [geonetwork.harvester] - Raised exception when searching : java.lang.NullPointerException
2012-10-03 00:00:01,703 WARN [geonetwork.harvester] - Raised exception when searching : java.lang.NullPointerException
In half day, the log file could become to a 150 G file. I wonder what's the problem and if you have some suggestions about this issue.
Best regards,
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
Dear Jesse,
These warning increases even though the geonetwork is not running. It's very strange. I stopped the geonetwork for a while, there are still many warnings writing to geonetwork.log.
2012-10-05 01:25:20,343 WARN [geonetwork.harvester] - Raised exception when searching : java.lang.NullPointerException
Best regards,
Kai
703-395-2337
----- Original Message -----
Date: Friday, October 5, 2012 0:19 am
Subject: Re: [GeoNetwork-devel] Log file (geonetwork.log) flooded with warning message
There are no stacktraces? that is annoying. Which harvester are
you using?
It sounds like one of your harvesters is misbehaving but the errors
are not
very explicit since there is no stack trace. You can manually
trigger each
harvester until you find the one causing the problems. Then you can
analyze the harvester itself to see what is wrong with it.
Jesse
days, the log
restarted the
> application:
exception> when searching : java.lang.NullPointerException
what's> the problem and if you have some suggestions about this issue.
> Best regards,
> Kai
> 703-395-2337
> Don't let slow site performance ruin your business. Deploy New
Relic APM
> Deploy New Relic app performance management and know exactly
> what is happening inside your Ruby, Python, PHP, Java, and .NET app
> Try New Relic at no cost today and get our sweet Data Nerd shirt
too!> http://p.sf.net/sfu/newrelic-dev2dev
> GeoNetwork-devel mailing list
> GeoNetwork-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
Solved. I killed all the java threads and then restarted the geonetwork. Currently the geonetwork.log is normal now.
Best regards,
Kai
703-395-2337
Date: Friday, October 5, 2012 1:31 am
Subject: Re: [GeoNetwork-users] [GeoNetwork-devel] Log file (geonetwork.log) flooded with warning message
Dear Jesse,
Best regards,
Kai
703-395-2337
> you using?
errors
> are not
> trigger each
> Jesse
> days, the log
> restarted the
> > application:
wonder
issue.> >
> > Best regards,
> > Kai
> > 703-395-2337
> Relic APM
app> > Try New Relic at no cost today and get our sweet Data Nerd
shirt
> > _______________________________________________
Relic APM
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
GeoNetwork-users mailing list
There are no stacktraces? that is annoying. Which harvester are you using?
It sounds like one of your harvesters is misbehaving but the errors are not very explicit since there is no stack trace. You can manually trigger each harvester until you find the one causing the problems. Then you can analyze the harvester itself to see what is wrong with it.
Jesse
In half day, the log file could become to a 150 G file. I wonder what’s the problem and if you have some suggestions about this issue.
Best regards,
Kai
703-395-2337
Don’t let slow site performance ruin your business. Deploy New Relic APM
