[GeoNetwork-users] log file messages on GNOS start up
Hi there,
I receive the following messages on start up (same for v2.6.0 and 2.6.1):
~/geonetwork_261/bin> start-geonetwork.sh
rm: cannot remove `logs/*request.log*': No such file or directory
rm: cannot remove `logs/output.log': No such file or directory
mv: cannot stat `logs/geonetwork.log.*': No such file or directory
mv: cannot stat `logs/intermap.log.*': No such file or directory
mv: cannot stat `logs/geoserver.log.*': No such file or directory
I can locate geonetwork.log, geoserver.log and output.log in ~jetty/logs,
but no intermap.log.
Is the intermap.log generated elsewhere? Can the start up messages be
ignored?
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/log-file-messages-on-GNOS-start-up-tp5746527p5746527.html
Hi Richard
Intermap was removed from 2.6.X and replaced by an OpenLayers map. I´ll
check to update the startup script to remove the reference to intermap.log.
If the log files are created correctly I think you can ignore the messages.
Jose García
On Wed, Nov 17, 2010 at 6:11 AM, RichC <richard@anonymised.com> wrote:
Hi there,
ignored?
Thanks.
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
