[GeoNetwork-users] Login error Invalid CSRF Token
Hello,
I asked a question (Error when Change the View from "Simple" to "Full" to
"XML") a few weeks ago but no one seems to have an answer for me. So i try
to install the new Version of Geonetwork 3.2.2.0
When I want to log in as "admin" I get the following error:
Type Status Report
Message Invalid CSRF Token " was found on the request Parameter '_csrf or
Header 'X-XSRF-TOKEN'.
Description The Server understood the request but refuses to authorize it.
Have I Forget something while I install the Software or is there another
solution to this error?
Thanks
Tanja
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi
Are you updating from previous GeoNetwork version? If thats the case and
also using an external data directory, you need to do some manual steps to
clean up some server cache files. I add here the note added to the release
mail:
*IMPORTANT NOTE FOR UPGRADING FROM PREVIOUS 3.x VERSIONS WITH EXTERNAL DATA
DIRECTORY*
If you use the default data directory in GeoNetwork, you can skip this note.
For those that are upgrading from a previous 3.x version and have
customised the data directory in a external folder (
http://geonetwork-opensource.org/manuals/trunk/eng/users/
maintainer-guide/installing/customizing-data-directory.html), before
starting up this new version you need to remove manually the old wro4j
cache files, otherwise will get the following exception:
    *Invalid CSRF Token '' was found on the request parameter '_csrf' or
header 'X-XSRF-TOKEN'.*
Please, search for the files (*wro4j-cache.h2.db*, *wro4j-cache.lock.db*)
in your data directory and remove them.
*This step should be done only once, before upgrading the version.*
Apologies for this inconvenience.
Otherwise if you're using a fresh install or just using the default data
directory, most probably is a issue of your browser cache, please try in an
incognito window to verify that works and cleanup the cache then.
Jose García
On Thu, Oct 12, 2017 at 10:43 AM, Tanja <tanja.ruecker@anonymised.com>
wrote:
Hello,
Type Status Report
Thanks
Tanja
f3860293.html
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
