I'm working on a multi-tool web portal witch include Geonetwork catalog, forum, web mapping with right management. Is it possible to log user into geonetwork from a previous authentification on the portal without having to log with username and password on the geonetwork home page.
Marc-André Goderre
Analyste en informatique
Centre de géomatique du Québec inc.
534, rue Jacques-Cartier E.
Saguenay (Québec) G7H 1Z6
magoderre@anonymised.com<mailto:magoderre@anonymised.com>
Tél. (418) 698-5995 poste 28
Fax (418) 698-4108
hello,
we will do a similar approach in the next half year. we want to integrate
geonetwork in our geoportal as a metadataeditor and -harvester. our portal is
php/postgres/mysql/apache/typo3 based and we have to integrate this
components with geonetworks java framework. for stability geonetwork should
run on another physical server. to do the integration, we plan to use
http://php-java-bridge.sourceforge.net/pjb/ for controlling the java sessions
by our php based portal.
this is the idea - the realization must be done
regards
armin
Am Dienstag 08 September 2009 19:26:23 schrieb Marc-André Goderre:
Marc-André Goderre
Fax (418) 698-4108
--- Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day trial. Simplify your report design, integration and deployment - and
focus on what you do best, core application coding. Discover what's new
with Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
