Everything was working fine running Tomcat 6. GN, GS, and Intermap were all
connecting and opening windows.
yesterday I came into work and Intermap no long connected. I have read that
it may have issues running on Tomcat, but it was working fine.
Any ideas on how to troubleshoot this problem or experience on what may
cause intermap to stop linking when I connect to GN. Still building and
connecting through 8080 localhost.
Have searched forums but not finding answers that apply, or things that are
way above my knowledge base.
Let me know what other info is needed.
In the Tomcat webapps/
Geonetwork
Intermap
geoserver (from geoserver.war)
in the conf/catalina/localhost folder I added the XML files for each app
Which GN version are you working on?
(FYI, Intermap was removed from trunk few days ago.)
In any case did you try to restart your Tomcat container?
Any other information in logs?
Mathieu
Geonetwork
Intermap
On Wed, Jul 21, 2010 at 7:00 PM, Divy <kivy@anonymised.com> wrote:
have restarted Tomcat container several times.
GN 2.4.2
Ok just checking you were not working on the head trunk.
Does this mean they are ready to replace intermap with OpenLayers?
Yes, Intermap was replaced by Openlayers.
This will be available in Geonetwork 2.6, comming in few weeks
(FYI, release candidate process started few days ago).
If that is the case, I have other stuff to worry about before making this
live.
But that hole in my GN page is annoying.
Check your logs or anything that can help to understand what's happen with
intermap webapp.
Do you also have Javascript error on the home page?
