Do we have a lucene index field that stores records' accessibility (public
or private).
I mean such a field using which a search can be made to get only public
records.
My requirement is to configure a csw entry point such that it filters only
public records.
I checked WEB-INF\config-lucene.xml and
WEB-INF\data\config\schema_plugins\iso19139\index.fields.xsl, but no such
field exists.
There is a dump field in config-lucene.xml like
<field name="_isPublishedToAll" tagName="isPublishedToAll"/>
but this cannot be used as a filter parameter in the new csw entry point
that I have defined to get only public records.
So the following does not work in config-csw-servers.xml
<service name="csw-public">
<class name=".services.main.CswDiscoveryDispatcher" >
<param name="filter" value="+_isPublishedToAll:true"/>
</class>
</service>
On Fri, Aug 14, 2015 at 1:30 PM, Ameet Chaudhari <ameet.chaudhari@anonymised.com>
wrote:
Hi All,
or private).
records.
public records.
field exists.
</class>
</service>
Does anyone know how to achieve this?
Ameet
I got the solution to above. It is to use either +_op0:1 or
+_groupPublished:all in the filter for the csw entry point.
