Hi, During my startup of my MacOS default installation in the Geonetwork.log
I get the following fatal error,
FATAL [jeeves.engine] - Exception :
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'MetadataRegionsDAO': Injection of autowired dependencies failed;
nested exception is org.springframework.beans.factory.BeanCreationException:
Could not autowire field: private org.fao.geonet.kernel.search.SearchManager
org.fao.geonet.services.region.MetadataRegionDAO.searchManager; nested
exception is org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'SearchManager' defined in URL
[jar:file:/Applications/geonetwork/web/geonetwork/WEB-INF/lib/core-3.4.4-0.jar!/config-spring-geonetwork.xml]:
Instantiation of bean failed; nested exception is
java.lang.ExceptionInInitializerError
Assistance would be appreciated.
thank you,
Joseph
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi Joseph,
Geonetwork.log
bean
failed;
nested exception is
Error
I've installed GN 3.4.4 using the installer in Mac OS X Mojave and I haven't
found the problem you describe.
Could you include a bit more of the log, please?
Juan Luis.
On Wed, Oct 24, 2018 at 11:39 AM Joseph Street <joseph.street@anonymised.com>
wrote:
Hi Juan,
Thanks for your message. I've installed GN 3.4.4 using the installer in
Mac OS X Mojave with JRE 8.
Afterwards, I use the startup.sh but it doesn’t get through.
Can you try this new version of startup.sh [1]?
Are you also using jetty/h2?
Yes, I'm using Jetty/h2 default config of the installer (without the
INSPIRE module).
[1]
https://github.com/geonetwork/core-geonetwork/blob/2f8f90ab4971ea0393ecaf0cd782c26c3df7d67c/release/bin/startup.sh
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
