[GeoNetwork-users] main.search returning TransformerConfigurationException error - GN 2.10.2 html5ui
geonetwork/srv/eng/main.search returning a
"TransformerConfigurationException : Failed to compile stylesheet. 7 errors
detected." error.
Any suggestions of where I can begin looking into this issue would be much
appreciated.
Many Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/main-search-returning-TransformerConfigurationException-error-GN-2-10-2-html5ui-tp5144719.html
Hi Shiree,
Have you loaded any additional schemas before you started getting this
error? It looks very similar to an error I was getting when I loaded the MCP
2.0 profile. Not a very helpful error message.
Byron
View this message in context: http://osgeo-org.1560.x6.nabble.com/main-search-returning-TransformerConfigurationException-error-GN-2-10-2-html5ui-tp5144719p5144758.html
detected." error.
Go into the log file of your geonetwork instance. You will get more
informations about the XSLT errors (files, lines etc...).
Florent Gravin
Camptocamp - Chambéry
0479444492
Thanks for the suggestions. Issue now resolved.
My fault sorry. In trying to resolve
http://osgeo-org.1560.x6.nabble.com/ANZLIC-record-default-view-view-mode-broken-GN-v2-10-2-HTML5UI-td5139884.html
<http://osgeo-org.1560.x6.nabble.com/ANZLIC-record-default-view-view-mode-broken-GN-v2-10-2-HTML5UI-td5139884.html&gt;
I broke metadata.xsl.
Kind regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/main-search-returning-TransformerConfigurationException-error-GN-2-10-2-html5ui-tp5144719p5144881.html
