I attempted to load the GCMD keywords (sciencekeywords.rdf) from
http://gcmdservices.gsfc.nasa.gov/static/kms/sciencekeywords/ using the
manage thesauri and got an error.
After downloading and looking at the file I noticed that there is the
following at the top of the file which does not seem to be SKOS compliant
So I removed it then tried to upload the fixed file. But now I get the
following error.
It complains that it already exist however I don't have any option to remove
it.
Anyone know how to remove this manually so I can reload the corrected
version?
using version: Geonetwork 2.8.0
Thank you
View this message in context: http://osgeo-org.1560.n6.nabble.com/Manage-thesauri-issue-tp5041433.html
Ian,
2013/3/19 ianwallen <ianwallen@anonymised.com>
following error.
remove
it.
version?
You should be able to remove it from WEB-INF/data/config/codelist probably
local/theme folder.
HTH.
Francois
Thank you
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-users mailing list
Francois,
Nope - that did not solve the issue. As this was a test instance I ended up
re-installing geonetwork to get it to load.
Now that I have the correct one loaded - I did a test where I tried to
reload it without deleting it using the interface. I deleted the RDF file
from local/theme as you suggested and it fails to load. Deleting the file
did not affect the interface - I could still see the information. I was able
to reload it if I deleted the entry using the web interface.
So it seems like the thesauri information is stored somewhere else. I did a
text search on the file system for sciencekeywords and I checked the
database tables and did not see anything.
After looking a little more into the initial error (see below) it looks like
openrdf may be creating a repository even though there were errors. I'm not
sure where this repository is stored.
I will try to look into some more....
View this message in context: http://osgeo-org.1560.n6.nabble.com/Manage-thesauri-issue-tp5041433p5041727.html
2013/3/20 ianwallen <ianwallen@anonymised.com>
Francois,
able
a
like
hum, even if restarting the catalog ? thesaurus should be initialized on
startup.
Francois
Francois,
Yep - removing the file and then restarting geonetwork fixed the issue.
But is is still a bug and I may look into it when I get time...
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Manage-thesauri-issue-tp5041433p5041736.html
Ian, I made a ticket for the record
http://trac.osgeo.org/geonetwork/ticket/1252 but I did not find why it's
failing to load.
Francois
Francois,
Thanks.
