[GeoNetwork-users] managing contacts
Thanks!
Francois Prunayre wrote on 2014-06-13:
2014-06-12 12:32 GMT+02:00 Hugo Ahlenius <hugo.ahlenius@...1316...
<mailto:hugo.ahlenius@…1316…> >:
  I am new to Geonetwork, and trying to evaluate it. I have 2.10.3
installed on a windows machine, as well as deployed on Ubuntu/Tomcat.
  As I understand it there is no simple interface to managing
contacts, right? One would have to enter them in metadata items, and then
using "fragments" and XPath to extract it into the directories (which are
accessible from the admin menu "manage directories")
Some users generate XML fragments from LDAP or CSV files containing
contact details and use batch import to load them in the catalog as
subtemplate. They can then use them in the metadata editor (and basically
manage contacts using other tools).
  Also - I am using the modern widget UI - the "Extract subtemplates"
option is not present in any of the menus, but I can see it if I dip into
the classic/old UI. Is this a bug?
I created an issue for that:
https://github.com/geonetwork/core-geonetwork/issues/558
Cheers.
Francois
  Hugo
  Hugo Ahlenius
  ------------------------------------------------------------- Hugo
Ahlenius E-Mail: hugo.ahlenius(at)nordpil.com
<http://nordpil.com> Phone: +46
75 7575284 <tel:%2B46%2075%207575284> Nordpil Mobile:
             +46 733 467111 <tel:%2B46%20733%20467111>
  http://nordpil.com Skype: callto:hugo.ahlenius
                Twitter: https://twitter.com/nordpil
         vCard: http://nordpil.com/hugoahlenius.vcf
------ HPCC Systems Open Source Big Data Platform from LexisNexis Risk
Solutions Find What Matters Most in Your Big Data with HPCC Systems
  Open Source. Fast. Scalable. Simple. Ideal for Dirty Data. Leverages
Graph Analysis for Fast Processing & Easy Data Exploration
  http://p.sf.net/sfu/hpccsystems
  _______________________________________________ GeoNetwork-users
mailing list GeoNetwork-users@lists.sourceforge.net
<mailto:GeoNetwork-users@lists.sourceforge.net>
Hugo Ahlenius
Hugo Ahlenius E-Mail: hugo.ahlenius(at)nordpil.com
                         Phone: +46 75 7575284
Nordpil Fax: +46 8 6747020
http://nordpil.com Mobile: +46 733 467111
