[GeoNetwork-users] Map UI layer grouping and WMTS issue
Dear all,
I'm trying to make the GeoNetwork map UI look better by grouping the layer
list by categories. My goal is to have similar drop-down menus for each
layer category than the default "Background maps" drop-down. Does anyone
have a solution on how to accomplish such grouping? I know the layer lists
can be configured in config-viewer.xml but I have not managed to accomplish
such grouping by configuring this file.
Currently our Map UI looks a bit messy as we have tens of layers in a
single list. See example screens on what I'm trying to accomplish here:
http://imgur.com/a/l99uA
Another issue I'm having is regarding WMTS. I'm trying to add WMTS layers
from http://gis.sinica.edu.tw/worldmap/ (
http://gis.sinica.edu.tw/worldmap/wmts?) to our GeoNetwork Map UI but
receive error message. In QGIS these WMTS layers work fine:
"Error: a.layer.getSource(...).getParams is not a function
g@anonymised.com://45.76.148.41:8888/geonetwork/static/gn_search_default.js:878:364
link@anonymised.com://45.76.148.41:8888/geonetwork/static/gn_search_default.js:879:388
ia/<@http://45.76.148.41:8888/geonetwork/static/lib.js:98:58
ma@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:98:117
n@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:83:405
Y/<@http://45.76.148.41:8888/geonetwork/static/lib.js:94:206
g@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:76:378
g@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:76:395
n@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:83:349
R/<@http://45.76.148.41:8888/geonetwork/static/lib.js:76:17
Yb/<@http://45.76.148.41:8888/geonetwork/static/lib.js:80:362
d@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:77:352
l@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:81:384
compile/</<@http://45.76.148.41:8888/geonetwork/static/lib.js:313:250
$watchCollection/<@http://45.76.148.41:8888/geonetwork/static/lib.js:157:30
$digest@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:158:119
$apply@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:161:33
compile/</<@http://45.76.148.41:8888/geonetwork/static/lib.js:285:444
dispatch@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:9:9954
add/y.handle@anonymised.com://45.76.148.41:8888/geonetwork/static/lib.js:9:6772
<li class="list-group-item ng-isolate-scope" data-gn-wfs-download="layer"
data-map="map">"
Thanks all for your help and replies!
*Aapo Kuusela*
*Web developer*
*RFO-SEA project*
*www.rfo-sea.org <http://www.rfo-sea.org>*
I am having the same issue. I want to group the layers in the GN map window
by categories. Does anyone have a solution?
Thank you in advance!
Johannes
-----Original Message-----
From: Aapo Kuusela [mailto:aapo.kuusela@anonymised.com]
Sent: Friday, June 16, 2017 1:05 PM
To: geonetwork-use. <geonetwork-users@lists.sourceforge.net>
Subject: [GeoNetwork-users] Map UI layer grouping and WMTS issue
Dear all,
Currently our Map UI looks a bit messy as we have tens of layers in a single
data-map="map">"
*Aapo Kuusela*
*Web developer*
*RFO-SEA project*
Check out the vibrant tech community on one of the world's most engaging
tech sites, Slashdot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
Hi
On Fri, Jun 16, 2017 at 8:04 AM, Aapo Kuusela <aapo.kuusela@anonymised.com>
wrote:
Dear all,
GeoNetwork layer grouping - Album on Imgur
Well you need to create a new directive to replace the layermanager.
Not easy to tell you what to do ....
In your directive create a structure with all your categories and then the
list off all layers by categories.
Watch BaselayerSwitcher template to get inspiration.
Do a ng-repeat on your categories, for each create a dropdown whom list
will be the list of all layers ..
You can perhaps reuse layermanageritem.html for the rendering of each item
maybe (but as it is in a drop down it won't be nice, i would more to a
collapsible panel).
Good luck
from Public Web Map Tile Service (WMTS) (
<http://sourceforge.net/projects/geonetwork&gt;
I could load your http://gis.sinica.edu.tw/worldmap/wmts
What layer do you want to add ?
I try to add layer i have no error, but i dont see the layer i have to admit
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
