I'm trying to configure the map so that when it is opened, its extent is set
to a specific location instead of the global perspective right away. Still
Figuring my way around GN, is mapService.js the file I'm looking for to
change?
Any help on this would be much appreciated
Thanks
Kevin
By default GeoNetwork uses this context file:
WEB-INF/data/data/resources/map/config-viewer.xml (if you're using an
external data directory, should be taken from that path instead of previous
one).
Not really sure if both are applied, please check to change the values in
config.js first to check if that works fine.
Jose García
On Thu, Jun 22, 2017 at 7:49 PM, Durkee <kevin_durkee@anonymised.com> wrote:
Hi
set
change?
Thanks
Kevin
View this message in context: http://osgeo-org.1560.x6.
nabble.com/Map-viewer-extent-tp5325236.html
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
