The file geonetwork/WEB-INF/config-gui.xml contains the configuration of
layers to show by default in mapviewer, you can update that file with
correct url to access the layers. See mapSearch and mapViewer sections.
Jose GarcĂa
On Thu, Feb 10, 2011 at 4:26 PM, RichC <richard@anonymised.com> wrote:
Hi there,
I'm installed GNOS but unable to get the maps to display in v2.6.3.
If you load that page with firebug open, you'll see that it tries to
load an url ending in wms?FORMAT=..., example:
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance. http://p.sf.net/sfu/intel-dev2devfeb
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
