Hola Jose,
Heikki Doeleman me ha ofrecido la posibilidad de que yo traduzca y vosotros
integreis el catalán en GN.
He desinstalado 2.6.1 e instalado la 2.6.2. Ahora me dedicaré a traducir los
strings en lugar de integrar el catalán en la 2.6.2, a la espera de la siguiente
versión GN con el catalán ya integrado.
Muchas gracias por el soporte y felices fiestas!
Montse
De: josegar74 [via OSGeo.org] <ml-node+5857045-627456410-96421@anonymised.com>
Para: mmarco <mmarcosabate@anonymised.com>
Enviado: mié,22 diciembre, 2010 12:56
Asunto: Re: Mapviewer strings in another language
Hi Montse
I get working for other languages with these steps:
* Check ca.js file for OpenLayers is available
(scripts/openlayers/lib/OpenLayers/Lang). I checked that is in GeoNetwork,
so should be ok
* Add your ca.js file to web\src\main\webapp\scripts\map\lang
* Edit web\pom.xml and add:
<aggregation>
<output>${geonetwork.webapp.dir}/scripts/lib/gn.libs.map.js</output>
<includes>
<include>${geonetwork.build.dir}/scripts/map/lang/en.js</include>
<include>${geonetwork.build.dir}/scripts/map/lang/ca.js</include>
* Edit web/xsl/geo/utils.xsl to load ca.js from OpenLayers:
<xsl:template name="geoHeader">
<xsl:otherwise>
<script type="text/javascript"
src="{/root/gui/url}/scripts/openlayers/lib/OpenLayers/Lang/en.js"></script>
* <script type="text/javascript"
src="{/root/gui/url}/scripts/openlayers/lib/OpenLayers/Lang/ca.js"></script>
Hope this solves your problem.
Jose García
On Tue, Dec 21, 2010 at 3:37 PM, mmarco <[hidden email]> wrote:
My GN (2.6.1) is customized to have also the catalan language. I need to
display mapviewer interface also in catalan (when catalan language is
selected). I tried to do that but is not working.
The steps I have made:
- I downloaded the svn 2.6.1 tag. Then, I copied the file
web\src\main\webapp\scripts\map\lang\en.js in a new one called ca.js. I
edited ca.js, translated the strings and changed two lines: line 15
(OpenLayers.Lang.ca= ) and line 133
(OpenLayers.Util.extend(OpenLayers.Lang.ca, GeoNetwork.lang.ca)
- In web\pom.xml I added next line
- I compiled with maven. I opened the gn.libs.map.js with a text editor and
I checked that the ca.js file is compressed into that file.
To test it, I copied the gn.libs.map.js in my server, but, unfortunalely
the
<mapviewer> strings still show in english instead of catalan.
I forgot something to do? What's the solution?
Thanks for your help and best regards,
Montse
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Mapviewer-strings-in-another-language-tp5855533p5855533.html
l
Lotusphere 2011
Register now for Lotusphere 2011 and learn how
to connect the dots, take your collaborative environment
to the next level, and enter the era of Social Business.
http://p.sf.net/sfu/lotusphere-d2d
GeoNetwork-users mailing list
[hidden email]
Lotusphere 2011
[hidden email]
View message @
http://osgeo-org.1803224.n2.nabble.com/Mapviewer-strings-in-another-language-tp5855533p5857045.html
To unsubscribe from Mapviewer strings in another language, click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapviewer-strings-in-another-language-tp5855533p5868924.html
