Further to this... I can get a selection into the session by doing a
search and selecting from the results. If I then, in the same session,
go directly to
http://localhost:8080/geonetwork/srv/en/metadata.massive.processing?proc
ess=keywords-comma-exploder (by pasting in the url) then I get a java
ConcurrentModificationException, but at least I am in the right class!
If I don't do the selection, then I get an xml response telling me that
the processing was done on zero records.
Clearly I am not doing this the right way!
Can anyone tell me how one should drive this process?
Justin.
Sent: 23 June 2010 10:30
To: 'geonetwork-users@lists.sourceforge.net'
Subject: Massive Xsl Processing.
Hallo all,
I am trying to use the various MassiveXslProcessing facility, but having
difficulty. Has anyone any experience for a quick discussion please?
Specifically, I need to implement a Search and Replace function. I can
write the xsl, put it in the right place, but I can't work out how to
give it a selection of documents to work with.
Any suggestions gratefully received.
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
