[GeoNetwork-users] Metadata Access Priviliges
Hello,
I understand from the documentation that access privileges are setup at
metadata record level. Is there a way to set this up at bulk for many
records at once instead of doing at each metadata record? Please advise.
Thanks.
Regards
Kumaran
Hi Kumaran,
I'm not used to metadata in GeoNetwork.But I see that metadata are sort by
group and the access Priviliges are set up by the group.
So you can change for many records if they are in a same group.
Stéphane
2011/7/15 Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com>
Hello,
Thanks.
Regards
Kumaran
AppSumo Presents a FREE Video for the SourceForge Community by Eric
Ries, the creator of the Lean Startup Methodology on "Lean Startup
Secrets Revealed." This video shows you how to validate your ideas,
optimize your ideas and identify your business strategy.
http://p.sf.net/sfu/appsumosfdev2dev
GeoNetwork-users mailing list
