[GeoNetwork-users] metadata additionally as local xml file
Hallo,
we use the geonetwork 2.2.0 to edit & manage our metadaten.
The metadata are stored in the data base, but we need them additionally as xml file on the server. Which script writes the data into the database and where I find this.
Or exists a script, which writes the metadata in a local xml-file.
Thanks for help and best regards
Joerg
hello,
i think you should wriet your own little php/perl/python/shell script it would
be the easiest way. the data is stored in one column - 'data'. you can
extract it and give each file a name which can be defined by other columns of
the table maybe: "schemaid'_'uuid'.xml'.
i would prefer php5 and the php-pgsql library to connect to the database.
best regards
armin
Am Mittwoch 04 Februar 2009 11:00:29 schrieb Joerg Matthes:
Hallo,
Joerg
--- Create and Deploy Rich Internet Apps outside the browser with
Adobe(R)AIR(TM) software. With Adobe AIR, Ajax developers can use existing
skills and code to build responsive, highly engaging applications that
combine the power of local resources and data with the reach of the web.
Download the Adobe AIR SDK and Ajax docs to start building applications
today-http://p.sf.net/sfu/adobe-com
GeoNetwork-users mailing list
Armin Retterath
Kompetenz- und Geschäftsstelle GDI-RP
beim LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Tel.: 0261/492-466
EMail: armin.retterath@anonymised.com
http://www.geoportal.rlp.de
There is no script that performs this action. The code that does this is Java. It's to be found in various classes in org.fao.geonet. If you re very comfortable with Java, Jeeves, and GeoNetwork, you might want to consider rewriting those classes to do what you need. Otherwise, you'll probably want to take the suggestion of another respondent and retrieve the material from the database directly, without touching GeoNetwork. Alternatively, you could write a script that uses the service xml.metadata.get. You could script curl or wget with a cron job (or its Windows equivalent) to sweep the range of records on some regular basis, writing them to disk.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Feb 4, 2009, at 5:00 AM, Joerg Matthes wrote:
Hallo,
Joerg
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Hello, Why not use GAST (Management/Export) to do a MEF export and unzip
those files to get the XML document ?
HTH. Francois
Hallo,
additionally
Joerg
Adobe(R)AIR(TM)
and code to
power of local
SDK and
Hi Joerg,
You could extend the function that is responsible for storing the metadata XML in the database with a function call that would write that same XML to the file system.
The class to look at is /geonetwork/src/org/fao/geonet/kernel/XmlSerializer.java
Ciao,
Jeroen
On Feb 4, 2009, at 11:00 AM, Joerg Matthes wrote:
Hallo,
Joerg
Ajax docs to start building applications today-Best Open Source Mac Front-Ends 2024
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
