[GeoNetwork-users] Metadata change date issue
After using Geonetwork v2.10.4 for a while and implementing some custom functionalities and layout for my company, I have been asked what the Metadata change date control is for (it is under the advanced options tab). The issue is that we use the 'metadata insert' option (updating only one file) or Batch import, it is not possible to find any results filtering by Metadata change date. However, the "sorted by: Change date" option from the main bar is working properly.
Taking that into consideration, what are the differences between these two options? Why is the metadata change date not working as it should be?
Thanks in advance.
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
