we're trying to migrate our infrastructure toward GN 3.x (we're already working with a 2.6.4). Since we usually generate metadata xml files (ISO 19115) and then upload them to GN, I was trying to test the import metadata facility from the gui.
Problem is that :
* an exception[1] is thrown regarding the metadata[2] structure but no report is displayed[3]
* the metadata[2] should be INSPIRE valid according to [4]
I also notice from [1] some strange behavior :
* 2017-02-06 14:34:44,553 WARN [geonetwork.schemamanager] - Cannot resolve http://www.w3.org/2001/03/xml.xsd: will append last component to current path (not sure it will help though!)
---- tried wget from shell/same user and I downloaded the xsd with no problem----
*2017-02-06 14:37:42,338 WARN [geonetwork.thesaurus] - No thesaurus found for concept scheme http://geonetwork-opensource.org/inspire-theme (lang=eng)
Error on line 249 of schematron-rules-inspire-strict.disabled.xsl:
Can these be linked to my problem?
Environment :
* geonetwork 3.2
* tomcat 7
* Ubuntu 14.04.4 LTS
* JAVA java version "1.8.0_111"
Java(TM) SE Runtime Environment (build 1.8.0_111-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.111-b14, mixed mode)
Attachments :
[1] Exception stack trace and error report
[2] metadata file "ISO_2947598415399019488.xml"
[3] ****removed**** report screenshot for limitation on mail size
[4] INSPIRE validation tool "http://inspire-geoportal.ec.europa.eu/validator2/"
Thanks in advance,
Fabio Sinibaldi
Fabio Sinibaldi
CNR Istituto di Scienza e Tecnologie dell' Informazione A. Faedo
Area della Ricerca CNR
InfraScience Group http://nemis.isti.cnr.it/groups/infrascience
Via G. Moruzzi, 1 – 56124 Pisa, Italy
Skype fabioisti
https://it.linkedin.com/in/fabio-sinibaldi-18779a18
(attachments)
Error.txt (92.3 KB)
ISO_2947598415399019488.xml (23.5 KB)
