[GeoNetwork-users] Metadata import failure: missing metadata file
Am trying to move my metadata from 2.03 to 2.1 but on a new machine. To do
so I figured I export my metadata using GAST which created a whole bunch of
mef files. When I run GAST on the old location and connect to the new
location it does not let me import the metadata there. The error message I
get is 'Missing metdata file: metadata.xml' after which it stops. I noticed
that there are 2 metadata.xml files in the old gast template folder but not
one for ISO 19115 which is what I am using. Has anyone had this before or
got any ideas what the solution might be?
Thanks ahead!
cheers,
Mark
View this message in context: http://www.nabble.com/Metadata-import-failure%3A-missing-metadata-file-tf4689900s18419.html#a13403902
Sent from the geonetwork-users mailing list archive at Nabble.com.
