I've used curl command,
curl -u admin -X POST -H 'Mime-type: application/xml' -T '/home/j/test.xml'
http://localhost:8081/geonetwork/srv/en/metadata.insert
But it gave the error message of
You may not have the privileges to do this operation
ServiceNotAllowedEx : Service not allowed
It would be really appreciated if anyone explains the solution to this
problem.
admin is administrator and test.xml looks like,
<request>
<group>Sample group</group>
<category>_none_</category>
<styleSheet>_none_</styleSheet>
<data>
</data>
</request>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/metadata-insert-error-tp6303364p6303364.html
The -u option of curl allows to provide HTTP basic authentication mechanisms
; geonetwork would not be able to handle this. You may have to hit another
service ( xml.user.login, taking username and password as argument), then
save the cookie, and reuse it on the metadata.insert webservice. I'm not a
CURL expert, but I'm sure there are some options to save the cookie, and
reuse it after successful authentication on the desired service.
Hth,
Pierre Mauduit
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)4 79 44 44 92
http://www.camptocamp.com
pierre.mauduit@anonymised.com
I really appreciate for your reply.
As your advice, I've tried xml.user.login like below,
curl -v -XPOST -H 'Mime-type: application/xml' -T '/home/j/user.xml'
http://localhost:8081/geonetwork/srv/en/xml.user.login
my user.xml looks like
<request>
<username>admin</username>
<password>password</password>
</request>
But I got the error message like below.
"The requested operation could not be performed
MissingParameterEx : username"
As you can see in my user.xml, there is a username.
Also, the verbose message of curl showed that
< HTTP/1.1 100 Continue
< HTTP/1.1 500 Internal Server Error
< Server: Apache-Coyote/1.1
< Set-Cookie: JSESSIONID=5FBFA5D210A509D3844F1EAAADA7FA68; Path=/geonetwork
< Pragma: no-cache
< Cache-Control: no-cache
< Expires: -1
< Content-Type: text/html;charset=UTF-8
< Transfer-Encoding: chunked
< Date: Mon, 25 Apr 2011 19:57:58 GMT
< Connection: close
It would be appreciated if you let me know any reason/solution regarding to
this matter.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/metadata-insert-error-tp6303364p6303785.html
As far as I remember, Jeeves (the framework used within GeoNetwork) does
handle GET and POST parameters differently. try to use
http://…/xml.user.login?username=blah&password=blah
instead (or find the option to use a GET instead of a POST query with curl).
Pierre
