[GeoNetwork-users] metadata language
Hey!
Is it possible to do something like this:
I insert 2 metadatas (using some template). The content is the same but
translated into 2 different languages. And then when viewing the metadata
i'd like to view an apropriate metadata according to the currently selected
language. So if i set the language to english i'd like to see the english
version of metadata and if i set the german language, i'd like to see the
translated, german version of the metadata.
Possible?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/metadata-language-tp5751456p5751456.html
I would say you don't need to have 2 different metadata records, you only
need one with multilingual content.
You could try to use the template "Template for Vector data in ISO19139
(multilingual)" to create such a metadata.
Then, you will be able to view the metadata content according to the
currently selected language.
HTH,
Mathieu
On Thu, Nov 18, 2010 at 1:31 PM, GeoUser <blazrepnik@anonymised.com> wrote:
Hey!
Possible?
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
