[GeoNetwork-users] Metadata privilages via CSW Transaction
Hi All,
I'm beginner at Geonetwork but not at CSW Catalog :wink: Is it possible send metadata privilages via CSW Transaction in Geonetwork, for example using SOAP protocol?
Hi Pawel
Metadata privileges are specific of GeoNetwork, you can't use CSW.
There's an option in the CSW configuration to make all metadata inserted
public (*Inserted metadata is public* option), that will make public any
metadata that is inserted using CSW transaction, see the option in:
http://SERVER/geonetwork/srv/eng/admin.console#/settings/csw
Also if you need different privileges for other groups, after adding the
metadata with CSW, you can use the GeoNetwork API to update the privileges,
check the code in
https://github.com/geonetwork/core-geonetwork/blob/3.4.x/services/src/main/java/org/fao/geonet/api/records/MetadataSharingApi.java
that has the services to manage about this.
Jose García
On Mon, Aug 27, 2018 at 4:03 PM Pawel Soczewski <psoczewski@anonymised.com>
wrote:
Hi All,
SOAP protocol?
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
