[GeoNetwork-users] Metadata validation and Inspire rules for the conformance degree [SEC=UNCLASSIFIED]
Hi Fabien,
ISO 19115 is implemented into XML using ISO 19139. ISO 19139 defines the
gco:boolean element as type xs:boolean. The definition of an xs:boolean type
is:
"An instance of a datatype that is defined as boolean can have the following
legal literals {true, false, 1, 0}."
Therefore, the only values available are "true", "false", "1" or "0". Hence
the INSPIRE use is incorrect unless INSPIRE has redefined the XML
implementation of the boolean type.
I hope that this helps.
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On
Behalf Of FBachraty
Sent: Saturday, 22 December 2007 1:49 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Metadata validation and Inspire
Hello,
A question about the Quality conformity degree
<gmd:dq_conformanceresult>
  <gmd:pass>
    <gco:boolean>0</gco:boolean>
  </gmd:pass>
</gmd:dq_conformanceresult>
In the Inspire rules for the conformance test, the degree is
specified as
the level of conformity of the resource to the related
specification. The
value domain of this metadata element is :
1. Conformant :The resource is fully conformant with the
cited specification
2. Not Conformant : The resource does not conform with the cited
specification
3. Not evaluated : Conformance has not been evaluated
But on the Geonetwork the values defined for the field are 0=fail and
1=pass.
Witch is the good specification : The Inspire or the Geonetwork one ?
For the moment the problem is that I can not fill in the
value "2 or 3" on
the degree metadata element or the metadata can not be validated.
  <gmd:pass>
    <gco:boolean>0/1</gco:boolean>
  </gmd:pass>
>> Valide
  <gmd:pass>
    <gco:boolean>2/3</gco:boolean>
  </gmd:pass>
>> Not Valide
Thank you.
Fabien Bachraty
View this message in context:
http://www.nabble.com/Metadata-validation-and-Inspire-rules-fo
r-the-conformance-degree-tp14456579s18419p14456579.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
So for the moment, i have to do the choice between the Inspire conformity and
the ISO 19139 one :wink:
Anyway i think that for the moment the INSPIRE conformity is not possible
with ISO19139 for this field and others like :
  Resource locator – connect point
  Coupled resource
  Classification of spatial data services ( Geographic service )
Thank you John for your answer.
Fabien Bachraty.
John.Hockaday wrote:
Hi Fabien,
type
is:
following
Hence
John
Behalf Of FBachraty
Hello,
  <gmd:pass>
  </gmd:pass>
specified as
specification. The
cited specification
specification
1=pass.
value "2 or 3" on
  <gmd:pass>
  </gmd:pass>
>> Valide
  <gmd:pass>
  </gmd:pass>
>> Not Valide
Thank you.
Fabien Bachraty
View this message in context: http://www.nabble.com/Re%3A-Metadata-validation-and-Inspire-rules-for-the-conformance-degree--SEC%3DUNCLASSIFIED--tp14588630s18419p14660398.html
