Alternatively, you could try to convince, coerce etc. INSPIRE to use the
correct format. ;--)
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On
Behalf Of FBachraty
Sent: Monday, 7 January 2008 7:53 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Metadata validation and
Inspire rules for the conformance degree [SEC=UNCLASSIFIED]So for the moment, i have to do the choice between the
Inspire conformity and
the ISO 19139 oneAnyway i think that for the moment the INSPIRE conformity is
not possible
with ISO19139 for this field and others like :
Resource locator - connect point
Coupled resource
Classification of spatial data services ( Geographic service )Thank you John for your answer.
Fabien Bachraty.
John.Hockaday wrote:
> Hi Fabien,
> ISO 19115 is implemented into XML using ISO 19139. ISO
19139 defines the
> gco:boolean element as type xs:boolean. The definition of
an xs:boolean
> type
> is:
> "An instance of a datatype that is defined as boolean can have the
> following
> legal literals {true, false, 1, 0}."
> Therefore, the only values available are "true", "false",
"1" or "0".
> Hence
> the INSPIRE use is incorrect unless INSPIRE has redefined the XML
> implementation of the boolean type.
> I hope that this helps.
> John
>> Behalf Of FBachraty
>> Sent: Saturday, 22 December 2007 1:49 AM
>> Subject: [GeoNetwork-users] Metadata validation and Inspire
>> Hello,
>> A question about the Quality conformity degree
>> <gmd:dq_conformanceresult>
>> <gmd:pass>
>> <gco:boolean>0</gco:boolean>
>> </gmd:pass>
>> </gmd:dq_conformanceresult>
>> In the Inspire rules for the conformance test, the degree is
>> specified as
>> the level of conformity of the resource to the related
>> specification. The
>> value domain of this metadata element is :
>> 1. Conformant :The resource is fully conformant with the
>> cited specification
>> 2. Not Conformant : The resource does not conform with the cited
>> specification
>> 3. Not evaluated : Conformance has not been evaluated
>> But on the Geonetwork the values defined for the field are
0=fail and
>> 1=pass.
>> Witch is the good specification : The Inspire or the
Geonetwork one ?
>> For the moment the problem is that I can not fill in the
>> value "2 or 3" on
>> the degree metadata element or the metadata can not be validated.
>> <gmd:pass>
>> <gco:boolean>0/1</gco:boolean>
>> </gmd:pass>
>> >> Valide
>> <gmd:pass>
>> <gco:boolean>2/3</gco:boolean>
>> </gmd:pass>
>> >> Not Valide
>> Thank you.
>> Fabien Bachraty
>> View this message in context:
>> http://www.nabble.com/Metadata-validation-and-Inspire-rules-fo
> r-the-conformance-degree-tp14456579s18419p14456579.html
> Sent from the geonetwork-users mailing list archive at Nabble.com.
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2005.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
http://www.nabble.com/Re%3A-Metadata-validation-and-Inspire-ru
les-for-the-conformance-degree--SEC%3DUNCLASSIFIED--tp14588630s18419p14660398
.html
