[GeoNetwork-users] Migrate from GPT3.1 to GN2.4.2
Hi GN list!
At the moment we're in a process of migrating from GIS portal toolkit
3.1 to GeoNetwork 2.4.2.
I read several times that there should be a CSW available in GPT3.1
which I can harvest. I tried the following URL
http://<website_name>/Portal/DiscoveryServlet?request=GetCapabilities&se
rvice=csw&version=2.0, however this doesn't respond with the regular xml
display. It displays the "Advanced Search page" instead.
Does anyone have experience on how to migrate metadata from GPT3.1 to
GN?
Thank you in advance!
Sidney Gijzen
hi Sidney,
I'm not familiar with GIS portal toolkit 3.1, but if it has a CSW server
capability then why not use GeoNetwork as a CSW client to harvest the data
from it ?
In GeoNetwork, log in as admin user, go to Harvesting Management, and set up
a CSW harvester pointing to your GPT installation.
If all goes well it should make copies of your metadata from GPT into
GeoNetwork.
Then, assuming you want to do this just once as a migration step, you'd need
to do some SQL queries to the database directly, to make GeoNetwork forget
this was harvested metadata and believe itself is the "source" -- otherwise
you can't edit them for example, and also because they would all be deleted
if you deleted that CSW harvester config.
Does this help ?
Kind regards
Heikki Doeleman
On Thu, Apr 8, 2010 at 5:14 PM, Gijzen, Sidney <sidney.gijzen@anonymised.com> wrote:
Hi GN list!
GN?
Sidney Gijzen
Download Intel&#174; Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
GeoNetwork-users mailing list
Hi Sidney
In this URL http://trac.osgeo.org/geonetwork/wiki/interop_matrix , there're
some CSW server urls, included ESRI CSW servers.
Also in one server I tested the next URL format was used (althought is quite
old, CSW 2.0.0):
http://SERVER/aimscsw/csw2.0?request=GetCapabilities&version=2.0.0&service=CSW
Hope can be helpful.
Jose Garcia
On Thu, Apr 8, 2010 at 5:30 PM, heikki <tropicano@anonymised.com> wrote:
hi Sidney,
from it ?
up
GeoNetwork.
need
Does this help ?
Kind regards
Heikki Doeleman
wrote:
> Hi GN list!
> GN?
> Sidney Gijzen
Thank you very much for your helpful replies Heikki and Jose! We are going to work with this information and we'll keep you informed on how it works out :).
Kind regards,
Sidney
-----Original Message-----
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: Thu 4/8/2010 5:50 PM
To: tropicano@anonymised.com
Cc: Gijzen, Sidney; geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Migrate from GPT3.1 to GN2.4.2
Hi Sidney
old, CSW 2.0.0):
Jose Garcia
hi Sidney,
from it ?
up
GeoNetwork.
need
Does this help ?
Kind regards
Heikki Doeleman
wrote:
> Hi GN list!
> GN?
> Sidney Gijzen
Download IntelĀ® Parallel Studio Eval
Hi list,
Please explain for me this question and show me where i can read an official definition (ISO or OGC).
I have a book which describes a location on the earth. Is the book a geospatial data?
best Regards,
Bui Hong Shon.
