I am using Geonetworks 2.10.2 and I have defined a virtual CSW based on the presence of a particular keyword. This works fine and I have tested that I can harvest the correct metadata using another Geonetworks as well as various POST and CSW requests via a script. However, I've just noticed that the full xml documents returned from this virtual CSW are actually missing the xml element where the keyword is defined - is this by accident or design?
Steve Donegan
