[GeoNetwork-users] modify search map
I'm getting started implementing GeoNetwork for our organization. After my initial demos, people really like the search withing bounding box. Of course then, I'd like to modify the default map that comes up in the search area on the "home" page of a GeoNetwork installation. I'd like to do three things.
1) automatically zoom to a specified area in the search map
2) use my own WMS map service I created in MapServer (MapServer is on the same machine now but may not be in the future) Do I need to use GeoServer?
3) change the orientation of the map window size to be portrait and a bit larger
Are these possible to configure, that is, without modifying source code and recompiling? Thanks for your help!
- John
John Callahan
Geospatial Application Developer
Delaware Geological Survey
University of Delaware
227 Academy St, Newark DE 19716-7501
Tel: (302) 831-3584
Email: john.callahan@anonymised.com
http://www.dgs.udel.edu
I have same problems with you
If you can find the way out
Please let me know
Thank You,
Pattrapong Tungkaserawong
to do three things.
GeoServer?
bit larger
- John
John Callahan
Tel: (302) 831-3584
Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
Studies have shown that voting for your favorite open source project,
along with a healthy diet, reduces your potential for chronic lameness
and boredom. Vote Now at http://www.sourceforge.net/community/cca08
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/modify-search-map-tp2014192p2161099.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
1) You need to modify:
    - For the small visor: geonetwork\web\intermap\scripts\im_minimap.js
        im_mm.setBBox(41, 1.3, 37.6, -1.9); //(for example)
    - For the big visor: geonetwork\web\intermap\scripts\im_bigmap.js
       im_bm.setBBox(41, 1.3, 37.6, -1.9); //(for example)
2) You need to modify the server list that is in the file geonetwork\web\intermap\WEB-INF\mapServers.xml
Services that appear by default at the maps are those that are between the <mapContexts><default> ...... </default></mapContexts> tags
For example:
<default name="Layers for default map -- DUMMY NAME:not used">
<server url="http://orto.cth.gva.es/wmsconnector/com.esri.wms.Esrimap/wms_parques_naturales?&quot; type="2" >
<layer name="provincias"></layer>
</server>
</default>
I hope this helps you.
Víctor
Víctor Centella Fuster
Prodevelop, Integración de tecnologías
http://www.prodevelop.es
Servei d'Informàtica
Conselleria de Medi Ambient, Aigua, Urbanisme i Habitatge
Francesc Cubells 7, 46011 València
Tel.: 96 197 3942
Email: asistenciagis1_ctv@anonymised.com
http://www.cma.gva.es
----- Original Message ----- From: "ZaTTeLLighT" <zattellight@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Thursday, January 15, 2009 7:30 AM
Subject: Re: [GeoNetwork-users] modify search map
Please let me know
Thank You,
to do three things.
GeoServer?
bit larger
- John
John Callahan
Tel: (302) 831-3584
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Thank you for your help Victor
These truly help me
I also has solution for problem #3 now
Try this ...
1> Go to 'geonetwork\web\geonetwork\xsl'
2> Edit 'searchform_simple_template.xsl'
3> Find 'im_mm_mapContainer'
4> Then change their dimension as you want
Hope this useful
Thanks again Victor
Pattrapong
Víctor Centella Fuster wrote:
For example:
<server
type="2" >
</server>
</default>
Víctor
Tel.: 96 197 3942
Please let me know
Thank You,
to do three things.
GeoServer?
bit larger
- John
John Callahan
Tel: (302) 831-3584
View this message in context: http://n2.nabble.com/modify-search-map-tp2014192p2167292.html
